Bottle jack ??
Discussion in 'Chainsaws and Power Equipment' started by Erik B, Nov 11, 2023.
  1. Erik B
    Erik B
    Western Wisconsin
    I have a 6ton bottle jack that quit working today. The release valve is closed and nothing seems to be broken or missing. It will not work. What could be the problem and would something like that we worth fixing?
    metalcuttr, In the Pines and wildwest like this.
  2. brenndatomu
    Does it leak?
    Could be low on oil...
  3. Erik B
    Erik B
    Western Wisconsin
    I don't wee it leaking. Where would you add oil to it?
  4. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I new one runs about $30-35 on Amazon or Wally World.
    It probably has a bad seal or is low on fluid. Check the fluid level first. If it's not low, I'd just buy a new one. They are easy to rebuild but locating the correct parts could take more time than it's worth.
    Loading up the Lopi
    Mike in Okla
  5. jmb6420
    jmb6420
    It should have a removable plug somewhere low on the barrel or base.
    Loading up the Lopi
    Mike in Okla
  6. jmb6420
    jmb6420
  7. Erik B
    Erik B
    Western Wisconsin
    Thanks guys. I will look at the jack tomorrow. I do have some hydraulic oil that I use in my splitter. That should work.
  8. Erik B
    Erik B
    Western Wisconsin
    It turned out to be a bit of air in the system. All I had to do was open the release valve and pump it 20 or so times, close the valve and it worked again.
  9. JD Guy
    JD Guy
    Upstate SC
    This happened to me several years ago. Topped off and still going!
