Both saws quit this morning.
Discussion in 'Chainsaws and Power Equipment' started by MaineMtnMan, May 25, 2018.
  1. MaineMtnMan
    MaineMtnMan
    Maine
    Is it possible to overheat saws? My Husqvarna 545 dies while working the wood pile this morning. I switched to my little 435 and that one died too . Both before I ran a full tank of fuel.
    I use e free fuel. .9 gallons to one can of oil.
    Any thoughts?
    Hammy, woody5506, bear 1998 and 5 others like this.
  2. basod
    basod
    Mount Cheaha AL
    You the only one that mixes the fuel?
  3. Screwloose
    Screwloose
    Are you possibly using winter blend fuel ? That can cause vapor locking.
    Hammy, MaineMtnMan, bear 1998 and 2 others like this.
  4. MaineMtnMan
    MaineMtnMan
    Maine
    Yessir
  5. MaineMtnMan
    MaineMtnMan
    Maine
    How do I remedy this?
  6. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Don't know about Husky but Stihl has a winter/summer shutter that needs to be switched when air temps rise above 50°. Does Husky have that feature? If you run the saw with the shutter in the winter position during warm weather, the saw could get hot and shut down, if you're lucky and it doesn't blow first. Although I haven't heard of a Stihl blowing for that reason.
    Hammy, bear 1998, basod and 5 others like this.
  7. OldJack
    OldJack
    Saskatchewan, Canada
    Get some fresh gas from a busy service station or try a jug of the pre-mixed alkylate fuel like Husqvarna ETHANOL FREE, High Octane Fuel, Aspen or Trufuel50.
    clemsonfor, Hammy, bear 1998 and 3 others like this.
  8. mike bayerl
    mike bayerl
    Get yourself some Stihl Pro saws! :D
  9. Backwoods Savage
    Not heard of this happening. Why do you mix .9 to one can of oil? Why not 1 to 1? That is what it is designed for.
    clemsonfor, Hammy and Ralphie Boy like this.
  10. M2theB
    M2theB
    Central Massachusetts
    Did you try them again after a full cool down?
  11. MaineMtnMan
    MaineMtnMan
    Maine
    I ran 1:1 and blew the 545 piston. Dealer thought I was running it to lean. I decided to go .9 to be safe. I would like to run the Husqvarna mix, but it's to expensive for the amount I use.
    Hammy likes this.
  12. RCBS
    RCBS
    Over here
    Since both saws are affected, my detector says fuel issue of some sort. Have you replaced your filters lately?
  13. MaineMtnMan
    MaineMtnMan
    Maine
    Well I rNr them today and both worked fine. Ran a tank of the same fuel through each. Im wondering if I was the problem.
    RCBS, M2theB, Hammy and 1 other person like this.
  14. MaineMtnMan
    MaineMtnMan
    Maine
    I'll tear them down tomorrow for a good cleaning
    RCBS, Hammy, basod and 1 other person like this.
  15. woody5506
    woody5506
    Upstate NY
    Does the 261c have this? I had issues last week while noodling big maple rounds. The saw quit and just wouldn't fire back up. Took it home, pulled the plug to check, put it back in and it fired up fine. Also I probably have winter blend fuel in it.
    Hammy likes this.
  16. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    winter blend...must be it
    basod, Hammy and woody5506 like this.
  17. OldJack
    OldJack
    The Stihl 261c has a winter-summer shutter. Page 25 of the Canadian manual.
    Ralphie Boy, Hammy and woody5506 like this.
  18. Dolphus Raymond
    Dolphus Raymond
    Deep South
    This.
    Ralphie Boy and Hammy like this.
  19. clemsonfor
    It's fuel related. But as they cool they should reatart.
    Just to check buy a quart of the canned fuel. It's a cheap way to check. In those small saws a quart should fill each one once.
    OldJack likes this.
  20. woody5506
    woody5506
    Upstate NY
    Thanks
    OldJack likes this.
