Blower is squealing....?
Discussion in 'The Wood Pile' started by Nordic Splitter, Dec 11, 2018.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    Hi Guys...Have a JotulF600 Stove with a Blower attached in back..Lately it has been squealing while running. Still works great but that squeal just has to go...Any thoughts on what it is and how I can fix it??? Thanks..:)
    mat60, T.Jeff Veal and Stinny like this.
  2. stuckinthemuck
    stuckinthemuck
    Have you cleaned it lately? I’m guessing you’ll need to remove it and partially disassemble it to be able to lube any bearings.. looks like an expensive unit.. if you can’t easily access the back of the stove, you might buy a spare so you can swap out as needed? Blower maintenance is something I try to do in the summertime so I don’t get surprised with a squealing blower during the dead of winter...maybe you can get a cheaper one on eBay.
    mat60, Marvin, Horkn and 3 others like this.
  3. stuckinthemuck
    stuckinthemuck
    Some discussion over here...
    mat60, Horkn and T.Jeff Veal like this.
  4. Nordic Splitter
    Nordic Splitter
    WNY
    I have to be honest.. The unit is 7 years old now and it has never been cleaned or shown any maintenance. I'm thinking of buying a can of spray air and just blowing the crap out of it and see what happens until the spring when I can take it off..:)
  5. stuckinthemuck
    stuckinthemuck
    Would be great if that worked.. We still have a long winter ahead of us.. Check YouTube also, Some videos on blower maintenance there. Good luck.
    Horkn, T.Jeff Veal and mat60 like this.
  6. papadave
    You know, I hadn't thought of canned air....until now.
    Having a similar issue for the last couple weeks or so. I pulled the stove out and used the shop vac on it, but it still wants to make annoying noises and vibrate.
    Canned air.....here I come!
  7. Stoveburner38
    Stoveburner38
    Springfield,ohio
    I wd 40 mine
    Maina, Urban Woods, mat60 and 3 others like this.
  8. Stinny
    I had a blower start squealing on the wood / coal furnace we had at the old farm. I learned to oil the motor's bearings, at each end, and that did the trick. There were tiny holes I'd put a couple drops of 3 & 1 oil in. Might help...
  9. ReelFaster
    ReelFaster
    S.Jersey
    Mine was vibrating a bit, but I adjusted the lid on top of the blower section and now its much quieter.
    Squealing sounds like it's in need of some some fine lubrication :thumbs:
    Maina, Urban Woods, mat60 and 2 others like this.
  10. Horkn
    3 &1 oil is the way to go. WD-40 won't last. InI'm su the fan blades are all clogged up with dust.
  11. bushpilot
    bushpilot
    Eastern Washington
    I just last night replaced the bearings in my blower on the NC-30. I had a squealing noise, and lubing didn't do the trick, because it has sealed bearings. Replacing them quieted it right down.
  12. TBONE
    TBONE
    Carey, Ohio
    There are videos out there on how to grease sealed bearings. Seems simple but if the bearings are cheap enough I'd just replace them also.
  13. Horkn
  14. Ejp1234
    Ejp1234
    MD
    My blower is taken down and cleaned/lubed every year at the end of the season. Ive seen how nasty mine is after 1yr, I cant imagine 7!!! The air it pushes out has to be taken in, and think of all of the dust/ash/soot at that spot.
  15. ReelFaster
    ReelFaster
    S.Jersey
    Am keeping an eye on my blower, I know it's brand new but on an insert it's used constantly so I wonder the life expectancy of a typical blower. I've been burning 24/7 since Sunday and while sometimes when the burn cycle is low it shuts off for a bit but not much so it's running almost constantly maybe a couple of hours break per day.
    brenndatomu and Horkn like this.
  16. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    Year five of hard running for the AC-16 hair dryer on my Englander 17. It occasionally makes a wonky squealing sound so I'm thinking it's just a matter of time. Look into a company called Fasco, they seem to make a lot of fans for different stove manufacturers and you might find the same one for quite a bit cheaper. Obviously if it's just a bearing (and replaceable) that's probably the cheaper route but food for thought. Using my AC-16 fan for example, could be replaced with a Fasco 50747-D401
    Centrifugal Blower 115V Fasco # 50747-D401 add a power cord and it would cost me less than half the $$$ of ordering the fan from the stove manufacturer.
    billb3 likes this.
  17. saskwoodburner
    saskwoodburner
    Do you have the hair dryer or the better version AC-30?
    Horkn likes this.
  18. Ejp1234
    Ejp1234
    MD
    Year 5 on my Lopi Freedom Bay. Its going to fail eventually, its mechanical... however with anything
    Mechanical if you take care of it, it will last longer.
    Horkn and ReelFaster like this.
  19. bushpilot
    bushpilot
    Eastern Washington
    The AC-30.
    saskwoodburner and Horkn like this.
  20. blacktail
    blacktail
    PNW
    Be prepared for a huge mess. I pull the blower of my Lopi 2-3 times a year and blow it out with the air compressor.
