Blaze King folks- door issue
Discussion in 'Modern EPA Stoves and Fireplaces' started by Beetle-Kill, Oct 14, 2016.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    My King has failed the dollar bill test. I've adjusted the catch previously, not sure how much tension it might take if I re-adjust. I already have a wear groove in the cam/latch.
    Am I OK to give the catch another turn, or is it time to replace the gasket?
    I'm thinking gasket. Thoughts?
    Thanks, JB
  2. rdust
    rdust
    SE, Michigan
    Give it a turn and see what happens. Worst case is replacing the gasket. I get two adjustments out of mine before replacing the gasket.
    I replaced my cam/latch with the newer style one last season. I like it better than my original one.
    Beetle-Kill likes this.
  3. Beetle-Kill
    Beetle-Kill
    When did they offer a new cam? Mines about 6 yrs. old. It wore in so quickly I have worried about it splitting at the wrong time if I increased tension too much.
  4. rdust
    rdust
    SE, Michigan
  5. Beetle-Kill
    Beetle-Kill
  6. Highbeam
    Highbeam
    I would keep tightening it until it bottoms out which will only be one or two turns. The old style latch threads into a welded in steel nut so you can only tighten one full turn at a time. The new stoves have an inner and outer nut, both loose so you can actually do a fine adjustment.
    The new gasket is like 30$ and has got to be BK gasket and not generic stuff. The gasket lays over and is expected to bridge/seal the door glass nuts so a healthy amount of silicone is needed.
    Door gasket is #1 important maintenance on these stoves. 95% of cat failures are due to door leaks according to BK.
    I would love to update to the new style latch since the old bent over bolt setup does gouge out the latch and defeats the ramp. Must a guy replace both sides of the latch or just the part that attaches to the stove body?
    papadave likes this.
  7. Beetle-Kill
    Beetle-Kill
    Gave the latch another turn, door sealed tight. Not too much additional pressure either, so I'm probably good , for now.
    I still need to contact BK for a correct fix.
    Thanks guys. :salute:
