Blaze King Ashford 30 BackPuffing
Discussion in 'Modern EPA Stoves and Fireplaces' started by Col.Kilgore, Dec 2, 2019.
  1. Col.Kilgore
    Col.Kilgore
    New Jersey
    Long time reader, first time poster.
    Switched out an old Vermont Castings Vigilant to a BK Ashford 30 last year to heat our 1,500 sq.ft. house.
    Burn times and heat output with the BK is a huge improvement, but...
    When we open the door to light/reload, we always get a little backpuffing. Not substantial, but you can always smell smoke in the room where the stove is afterwards. I'm following all the mfg's directions, opening the door super slowly, cracking a nearby window, but still having issues. Never had an issue with smoke odor from the Vigilant.
    Wondering if the backpuffing is due to a bad draft because of an oversized flue. When I swapped the Vigilant for the BK, we replaced the 8" stovepipe with 6", but left the 8" diameter chimney pipe in place, and used a reducer/expander coupling to go from 6" to 8".
    Any other suggestions or ideas would be greatly appreciated. Thanks!
    T.Jeff Veal, Slocum and wildwest like this.
  2. Woody Stover
    Woody Stover
    Southern IN
    That sounds like smoke roll-out, not a back-puff, where the door is closed and smoke in the box ignites suddenly, forcing smoke out of the box or connector pipe into the room. The BKs need good draft. How tall is your flue, and what is its configuration (elbows, etc?) I'm not a chimney expert, but it may be possible to run 6" inside of the 8", or just go ahead and remove the 8" and replace with 6".
  3. brenndatomu
    Have you called BK? I think this was an issue on some of these stoves...if you do a google search you will come up with some pretty longs threads on the subject. That 8" flue isn't helping the issue I'm sure...might want to pull a 6" liner in.
    Oh, and welcome to FHC! :handshake:
  4. Col.Kilgore
    Col.Kilgore
    New Jersey
    I think you're right Woody Stover. No elbows in the flue and the flue is about 15' total. I'd rather not replace the chimney pipe b/c that's a substantial cost. I could probably fit a liner inside the chimney.
    T.Jeff Veal and wildwest like this.
  5. moresnow
    moresnow
    Bet the BK isn't happy with the 8". You could try pulling the cap and adding a section of cheap snap together single wall to see if just adding more 8" would cure your issue. Assuming you are opening the bypass and twisting the stat wide open for a bit before opening the door?
    T.Jeff Veal, Hoytman and wildwest like this.
  6. wildwest
    Wyoming high plains
    x2
    T.Jeff Veal likes this.
  7. Col.Kilgore
    Col.Kilgore
    New Jersey
    Yup, doing that. I'm going to try to leave the door cracked for a bit, wait until the flue temp comes up, then open the door to load. Thanks again for the help.
  8. Well Seasoned
    Leave that stat open, crack the door and see if that helps. Is your wood dry, I mean really dry? Always good to resplit a piece and test with a moisture meter on the fresh split section. Should be less than 20%
    And just to make sure during reload you are opening that damper correct?
    T.Jeff Veal and Maina like this.
  9. Col.Kilgore
    Col.Kilgore
    New Jersey
    Damper is definitely open. I made that mistake once in the bleary-eyed early AM once.
    Wood is dry, I don't typically re-split and check with a meter, but I don't burn anything more than 15%.
    T.Jeff Veal and Well Seasoned like this.
  10. Well Seasoned
    Ok, able to look up chimney with a mirror and flashlight from inside the damper area at all just to make sure it's clear?
  11. Well Seasoned
    Was it not a very cold day when you were lighting up? Sometimes if it's not real cold out you'll have drafting issues
    Any other fans on? Above oven, in a bathroom etc
    A rare occurrence here, but if my oil kicks on early in the morning and I light the stove, sometimes I experience reverse draft. The blower is pulling to much air
  12. Col.Kilgore
    Col.Kilgore
    New Jersey
    I'll take a peek at the damper to make sure it's clear, but I'm confident it is. Cleaned 'er this year and went hog-wild with the shopvac inside the stove. This also happened when the stove/stovepipe was brand new.
    No other fans on.
    I do radon mitigation, so have experience with differential pressures in buildings, it's amazing how much vacuum a range hood will pull.
  13. Woody Stover
    Woody Stover
    Southern IN
    Straight up is good but 15' is marginal for an Ashford. You'll need to upgrade, I fear..
  14. Well Seasoned
    Maybe add a couple more feet. Class A chimney correct?
  15. Col.Kilgore
    Col.Kilgore
    New Jersey
    I was thinking that would be a potential solution. It's class a, extends 2' above the roofline.
  16. Well Seasoned
    It wouldn't hurt. I don't feel the transition from 6 to 8 will effect things in a negative way that much. We are a blaze king dealer. One thing they don't advertise is to get the absolute best burn cycles, the pipe needs to be installed x,y,&z. No 90s, only two 45's ect.
    Adding maybe another 4ft section should help. You could call a reputable stove shop in your area, have them come out and take a look which kind of class A you have, or if you can see it from the ground or a ladder, you want to match the brand. My guess is if your shops are busy like ours, it may be a few weeks to get someone out there.
    When did you get your blaze king installed last year?
    T.Jeff Veal, lotifoazurri and Maina like this.
  17. Woody Stover
    Woody Stover
    Southern IN
    I might try 6" first, depending on your priorities. Cheaper and easier to just slap another section of 8" chimney on, but it may not look as nice with more chimney up there. Also, the BK can run with low flue temps, so keeping flue gas temp up is a priority to keep the chimney cleaner. 8" hurts you there. Area of 6" is 28 sq.in, 8" is 50, but I'm not sure how that would equate to actual percentage of draft lost. Is your cap above the ridge, or just 2' above the roofline? If the cap is lower than the ridge, on the leeward side of prevailing winds, wind could push down at certain times, complicating things..
  18. BKVP
    BKVP
    Walla Walla WA
    So to be clear, the spillage and smoke smell are related to opening door to start or refuel the fire?
    If this is correct, do you have a F/A connection?
    Is the black stove pipe double wall or single wall?
    Please address these questions and we can go from there...
  19. Woody Stover
    Woody Stover
    Southern IN
    What's that?
  20. Highbeam
    Highbeam
    Fresh air connection also known as an OAK.
    Well Seasoned and Woody Stover like this.
