birch?
Discussion in 'The Wood Pile' started by bang, Oct 10, 2018.
  1. bang
    bang
    South central Indiana
    I'm pretty sure this is birch and I've never burned any. From the weight and looks I'm guessing its better than yellow poplar and similar to silver maple. I have a 16 to 18 inch log of it down a couple years but off the ground next to a trail so it's easy to get. At best I figure its shoulder season wood but is it ok for a fireplace (popping)? 20181010_082406.jpg 20181010_082424.jpg
  2. farmer rob
    farmer rob
    Dundalk Ontario Canada
    Honestly to me it is Poplar not Birch.I say that as that is all we have around here on our farms in Ontario and I have cut many hundred of them down for fire wood over the years.
    T.Jeff Veal, OldJack, Chaz and 4 others like this.
  3. bang
    bang
    you could be right, it has different bark than the tulip poplars that are common here.
    Chaz, Backwoods Savage and bear 1998 like this.
  4. bang
    bang
    the bark is gray similar to beech but a little darker and slightly rougher. I have about 10 of these trees in a grove but this is the 1st one to fall.
  5. papadave
    Looks more like the Poplar we have up here.
    If you pull off some bark, is it stringy?
  6. bang
    bang
    The wood does look like tulip poplar but possibly a little more dense. I think the bark was stringy but can't remember for sure. It's raining now so I'll check later.
  7. Fanatical1
    Fanatical1
    My vote is Aspen also... Called poplar or popple also. As Papadave said, the bark when pulled off is stringy.
  8. MikeInMa
    Whatever it is, get it up off the ground. If it's been down a long as you state, it may already be going punky on ya.
    OldJack, Chaz, bang and 3 others like this.
  9. Backwoods Savage
    Yes, do not think this is yellow poplar (or tulip) as yellow poplar is not even in that family!! Yet, this does look like poplar; aspen type poplar, or as most call it, popple.
    MikeInMa, Fanatical1, huskihl and 4 others like this.
  10. bang
    bang
    It fell across another log and isn't touching the ground and at a perfect height to buck
  11. bogydave
    Thinking it’s aspen
    Dries fast, burns fast
    A years of seasoning &
    It Shouldn’t pop like spruce,
    Ok for fireplaces
  12. Jon_E
    Jon_E
    Southwestern Vermont
    Populus grandidentata, aka American aspen or white poplar. Not to be confused with tulip poplar, or Liriodendron tulipifera. The sapwood appears to be rotten already.
  13. bang
    bang
    I'm learning a little today. I actually had aspen in my mind but I thought aspen was birch, not very common around here.
    I think you're correct, it's definitely not tulip poplar, the bark is completely different.
    bear 1998, Backwoods Savage and Chaz like this.
  14. bang
    bang
    I cut some last year that was blocking my pathway and this is a piece of that and it has been on the ground.
  15. chris
    chris
    SE WI
    a year down and still in the wrapper Birch would be total punk by now, on or off the ground. With Birch you have carve a section of bark off or it will go punky super quick.
    bear 1998, blacktail, Horkn and 4 others like this.
  16. huskihl
    huskihl
    Hard to tell, but by the bark pic, if it has a blue hue it's beech. If it has a green hue, it's white poplar. The split looks like white poplar.
  17. papadave
    Yeppers.
    I just finished css 1/3 cord of Birch recently.
    That pic isn't Birch.
    bear 1998, Horkn, bang and 3 others like this.
  18. bang
    bang
    d
    definitely not beech
  19. Horkn
    That's definitely poplar.
    It burns well, just fast.
  20. Oakman69
    Oakman69
    Mechanicsville
    I dunno smooth barks are associated w beech or hollies but heart wood and sapwood look llike poplar. ..balsam poplar I think.. handy trick for black and yellow birch is to scrape off the top bark and sniff the green cambium underneath ..If it smells like wintergreen, you know you’ve got yellow or black birch.
    Slit it stack it burn it next year. All wood is good... dry. Even most pines but oaks are the best imo..
    bear 1998, bang and papadave like this.
