Better than freezing!
Discussion in 'The Wood Pile' started by Crodog, Feb 27, 2015.
  1. Crodog
    Crodog
    Massachusetts
    Out to my shed today, 22 degrees out and 27% humidity out according to the weather channel. I know frozen wood doesn't dry so at least I'm making progress!
    cnice_37, splitoak, Drvn4wood and 8 others like this.
  2. Paul bunion
    Paul bunion
    You are definitely making progress. Rule of thumb is that for every 20 degrees F that the temp goes up the RH gets cut in half. You raised the temp by more than 20 so the RH should be <13% in the shelter. You instead have 62%. That moisture came from somewhere.
    (And not that frozen wood doesn't dry, it does, but at a much slower rate.).
  3. Backwoods Savage
    Crodog, wood will indeed dry in freezing weather. Not as fast as in summer months but it will still dry. If you don't believe this, check with some of those good folks who make Alaska their home.
    But, it won't dry in that shed! Why? Because of lack of air circulation. This is why most of us will not stack wood inside a shed until it has had time to dry outdoors.
  4. papadave
    Open up both ends and let that thing breath.
    wildwest and cribbed ends like this.
  5. cribbed ends
    cribbed ends
    East Tennessee
    Yes, let er breath!
  6. Sam
    Sam
    Southern Minnesota
    But then he'll lose all the heat. It's a catch 22 I believe.
    I think the "conventional" wisdom is that as long as the moisture is driven out of the wood under increased temps then the wood reabsorbs it much slower if at all, or something like that. It's the solar kiln principal.
  7. papadave
    Ah, didn't realize you were shooting for a kiln process.
  8. Sam
    Sam
    Southern Minnesota
    I'm not positive he was, just suggesting that if the goal was to get it above freezing to dry quicker then he lose that gain if he opens it up. I'm not expert but I play one on TV :)
    Shawn Curry likes this.
  9. KaptJaq
    KaptJaq
    Long Island, NY
    A few years back I made a shed similar to your's out of black tarps over a 2x4 frame. I put a small attic vent at the top center. When the sun hit it the air would warm up and move up in the stacks. The fins on the attic vent would spin showing some air movement. The moist air would go out the top and cool dry air would be sucked in at the bottom to absorbe more moisture. Does yours have some way of opening a vent near the peak to let some air move? Too big of a vent and the air barely gets warm before it moves out, too small and it stays moist inside. Your thermometer shows you've got the heat part right, now just add a little circulation.
    KaptJaq
    Sam likes this.
  10. Loon
    Loon
    North of the border
    Looks a lot better than what the hell I'm looking at right now Crodog!:hair::yes: Did a little plowing again today but gave up..:whistle:
    Pic through the back door as there is kinda a mountain of white stuff keeping us in.:cheers:
    Shawn Curry, Backwoods Savage and Sam like this.
  11. MarylandGuy
    MarylandGuy
    Maryland
    You have a little more snow than we have in the Mid Atlantic, but I think somebody from Boston would laugh if you called that a "mountain of white stuff".
    Backwoods Savage and Loon like this.
  12. Loon
    Loon
    North of the border
    Silly Me! at the back window out the kitchen.:coffee:
    Gotta love the mountain/ drifts coming over the house eh Guy.:yes: Some of the barbeque is involved also.:hair::D
  13. MarylandGuy
    MarylandGuy
    Maryland
    Now that's more like it!
  14. Crodog
    Crodog
    Massachusetts
    Snow is melting, mud is forming! Just went out to my woodshed and its 97 degrees and 25% humidity, certainly drying faster than stacks outside!
    Sam, Shawn Curry and wildwest like this.
  15. MarylandGuy
    MarylandGuy
    Maryland
    Snow flakes are like grand kids, eventually they go away.
    papadave and cnice_37 like this.
