Best wood for a splitting round
Discussion in 'The Wood Pile' started by Yawner, Jan 6, 2021.
  1. Yawner
    Yawner
    Louisiana
    What do you guys and gals think is the best species for a splitting round that you set your rounds on top of to split? Hopefully, something that lasts a few years! Wonder how long one would last. Also needs to be pretty tough wood because the axe can bottom out piercing the top of the splitting round. And rot-resistant since it's sitting on the ground, which usually means it absorbs moisture. With that said, I wonder if osage orange or black locust would be good. And oaks come to mind. Hmmm... wonder if you need one that does not have sapwood.
    Or has anyone used anything other than wood, lol? A giant block of hard plastic, lol. That would certainly be tough and would not rot.
  2. Homemade
    Homemade
    Wisconsin
    12” I beam
    Or yellow elm. Very twisted grain. Won’t split easy if you over swing and burry the splitting ax, wedge, maul...
    Midwinter, Cash Larue, CHeath and 3 others like this.
  3. buZZsaw BRAD
    We would always use the biggest round (usually the stump cut off) for a "chopping block" as we always called it. I have a huge maple stump in my old PA that i scrounged three Summers ago. Heavy as hell and still cant believe i got it on the truck by myself. IMG_1848.JPG IMG_1849.JPG
    Ive used it for noodling too. Now ill just grab a big round from a current load and use that.
    Oak or BL would make a good long term one IMO.
    Midwinter, Cash Larue, CHeath and 4 others like this.
  4. iowahiker
    iowahiker
    NE Iowa
    Concrete, I always split in the same place, right where I unload.
    Midwinter and Chazsbetterhalf like this.
  5. Horkn
    Elm. You could whack that a million times with an axe or maul and it will just laugh at you.
  6. Yawner
    Yawner
    Louisiana
    That's a good idea!
    I wonder about black gum. If it is resistant to rot. It's certainly resistant to being split! Sweetgum is too but I don't perceive it as rot resistant.
  7. SammyWhammy
    SammyWhammy
    Blue Earth Minnesota
    I’ve been using a cottonwood round for the past couple years. It’s held up great and when it goes, who cares it’s cottonwood.
  8. moresnow
    moresnow
    I've had a couple huge Maple rounds to split on for years. Big enough to hold my 15" tire at just the correct height. I do tip it on edge to shed moisture when not in use.
  9. Horkn
    Elm certainly doesn't rot quickly. I've heard stories about gum too in regard to splitting resistance.
    Midwinter, Cash Larue, Yawner and 2 others like this.
  10. woody5506
    woody5506
    Upstate NY
    Black locust or honey locust for rot resistance, or elm. But all I have is a chunk of maple that I've used since 2016 when I got my stove. I'd still say its dang near perfect, fungus growth and all.
  11. Erik B
    Erik B
    Western Wisconsin
    I have to say elm is good wood for a chopping block. If you can find one that is a nice crotch piece that won't split easy you would have one that may last years.
    Midwinter, Cash Larue, Horkn and 3 others like this.
  12. Mag Craft
    Mag Craft
    South East Wyoming
    I have used Cottonwood, Elm, and spruce. I usually change them out every year. I will take the old one and split it and then stack it with the rest.
    Midwinter, Cash Larue, Yawner and 4 others like this.
  13. Boogeyman
    Boogeyman
    Central Indiana
    I'll usually use a bigger round of whatever I'm cutting for a chopping block like buZZsaw BRAD mentioned. I've kept a few for a while before, usually crotch pieces that I dont want to split. If I plan to keep it then I try to put it on top of concrete blocks or some flat concrete pieces so it doesnt sit on the dirt and rot the bottom.
  14. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I have been using a large, knotted black cherry round that I will eventually have to noodle. Also a very large black locust round that refused to be split with the fiskars.
    Midwinter, Cash Larue, Erik B and 2 others like this.
  15. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I set them on a 22 ton Speeco, going on 10 or so years and haven't needed another one yet.
  16. Cash Larue
    Cash Larue
    Pine, CO
    X2 :yes:
    Midwinter, Mag Craft and Horkn like this.
  17. Sinngetreu
    Sinngetreu
    North Central Iowa
    I use whatever is lying around. I made one more "permanent" by bolting a tire to it and coating it with used oil to preserve it more.
  18. BuckeyeFootball
    BuckeyeFootball
    I'm currently using a big cottonwood round and its on year 3.
    Midwinter, SammyWhammy and Mag Craft like this.
  19. mr.finn
    mr.finn
    Mass
    I have a big white pine round, like others said when it starts to rot either split it or throw it away, it is readily available. When you need to put your axe somewhere just it sticks in pine with little effort
    Midwinter and Mag Craft like this.
  20. Yawner
    Yawner
    Louisiana
    Now that is a good idea if it works. How did you put the oil on? I have some used oil and I need a tire-on-a-block.
