Best loose fill insulation for chimney liner install?
Discussion in 'Modern EPA Stoves and Fireplaces' started by bobdog2o02, Sep 5, 2018.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm going to be helping my cousin install a drolet insert in the next few weeks and wondering what is the best/easiest thing for pouring down to insulate? Mica? Roxul? The next thing is where is the best place to get it.... Thanks for any help in advance
    Eric VW and ReelFaster like this.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I filled mine with perlite,got it at agway
    Eric VW and bobdog2o02 like this.
  3. ReelFaster
    ReelFaster
    S.Jersey
    I stuffed the throat with Roxel after the liner had been pulled.
    Eric VW likes this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    was this loose or did you have to shred it off of a batt?
    Eric VW likes this.
  5. ReelFaster
    ReelFaster
    S.Jersey
    It was batts and I cut & pulled what I needed to stuff up there. I stuffed as much as I could until it was snug and tight all around the area, especially around the liner. I also put a block plate in with roxel on the opposite side. Can't really see it that well in this pick but I basically flipped the block plate and cut a batt of roxel to match the size of the block plate minus the hole for the liner.
    Maina, Eric VW and Marvin like this.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Do you mind giving me a little info since this is what i was thinking of doing but dont know how much it will take....
    What liner size? 6"?
    How tall was you your chimney?
    What size was the masonry chimney, inside dimensions?
    Thanks!!!
    Eric VW likes this.
  7. Eric VW
    I was gonna suggest either Perlite or Vermiculite.... don’t know the cost difference.
    Stuff the bottom with some Roxel/rock wool, calculate the volume of his stack minus the liner and buy accordingly. :yes:
    ReelFaster and SKEETER McCLUSKEY like this.
  8. moresnow
    moresnow
    Only had room for a un-insulated liner? Curious.
    Eric VW, bobdog2o02 and ReelFaster like this.
  9. ericdm2004
    ericdm2004
    michigan
    Eric VW, Maina and bobdog2o02 like this.
  10. Gark
    Gark
    SW Michigan
    Thermix.
    Maina and Eric VW like this.
  11. brenndatomu
    I know most chimney pros refuse to do loose fill...for several reasons.
    The biggest one is that there is almost no way to make sure you have proper CTC (clearance to combustibles) because the liner will not hang totally straight and in the center of the flue...and very few chimneys actually have proper CTC believe it or not...the biggest problem is on most chimneys it is near impossible to verify if it is built proper or not.
    Also, it can be hard to keep loose fill from running out any little crack.
    And if you ever try to do any work on anything, the loose fill will come running out and make a GIANT mess!
    Maina, Eric VW and bobdog2o02 like this.
  12. brenndatomu
    And here is a good example of what happens when you give vermiculite a place to "leak" to...Outdoor Wood Boiler Plan & Install (5th pic down)
