Basic top end swap /Solo 665 becomes Solo 681
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Nov 3, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    As the title says, I am going to pop the top on the Solo 665 (65 cc) and make it a Solo 681 (81 cc).
    While I am at it? I will explain (somewhat briefly) how to do this yourself. If you ever decide to do a saw yourself? Post a thread, ask questions, and take pics.
    There is quite a few steps involved. But nothing the average homeowner can not do.
    For this saw? You will need a 4 mm allen, 5 mm allen, a T-25 torx bit, and a flat head screwdriver. I may have forgotten a few small things I used, but these are the main tools for this saw. A Stihl will use the T-27 mainly, and a Husq uses a lot of 4 mm and 5 mm.
    Here is the saw and parts in question. Even though this saw is gaining 16 cc, it would be the same swap if it was an aftermarket top end or OEM top end of the same size.
    First, we have to remove the plastics and the wrap handle (you don't have to remove wrap.. But taking it off makes life much easier).
    Once all the plastic and the wrap are off, your next move will be the jug. On a Dolkita or Solo, removal of the entire assembly (carb, boot, cylinder) is the easiest. But you can remove the carb, boot, and jug, a separately.
    You need to make sure the fuel tank is empty before the next step. Remove the fuel line and loosen the four 4 mm allen bolts that hold the cylinder down.
    (Notice the visible oil :) 36:1 :dex: )
    Once you have the cylinder off, if your going to "up" the size of the saw? The piston has to come off. So you need to remove one of the circlips (these can be a PITA).
    Then pull the wrist pin.. a small deep well socket works well for this.
    And finally, the A/V spring has to come off the old jug and be put on the new jug..
    Now you have the saw broke down and ready to get all the new parts ready for assembly.
    $ooline, PullinMyPoulan and cnice_37 like this.
  2. DexterDay
    Northeast Oh
    Remove the carb and impulse from the old cylinder and place on the new jug.
    Then install the A/V spring on new jug.
    Before you reinstall the cylinder bolts, clean any Loc-tite that may have been on them, be sure to reapply some before you install.
    This pic shows the difference in size of the Pistons :)
    Now it's time to put everything on. I use good 2 - cycle oil as an assembly lube. Put some on the needle bearing, wrist pin, and piston skirt/ring. Put the piston on and install circlips (I install one before getting it on saw, then install the other after wrist pin is installed). Make sure the arrow on the piston, points towards the exhaust port.. Always..
    Because this is a single ring saw, it's pretty easy to compress the ring and place the jug over top of it. Make sure to apply some 2 cycle oil on the cylinder walls before sliding piston in.
    Then torque the cylinder bolts down to 14 NM (on this saw). Please refer to your specific saws torque specs.
    After a few heat cycles, it's a good idea to check the torque again. Just to be sure.
    $ooline, Cut4fun and cnice_37 like this.
  3. DexterDay
    Northeast Oh
    The only thing I did to this saw, as far as a mod goes? Is to clean up the window casting. There is a thin casting flaw that's about 1/64" around the O.D of the windows. I used a dremel and cleaned those windows up..
    And here. You can see the the Big Bore jug (81 cc) is lighter by over 3 oz, over the 65 cc jug.
    I know I probably forgot about a dozen things (like the gasket, checking squish, etc). But I have promised this thread for 2 days and it's getting late. Took a while to build the saw and a while to do this thread.
    Here is the finished saw. Was a 665.. Now a 681! :dex:
    $ooline, cnice_37, 343amc and 6 others like this.
  4. DexterDay
    Northeast Oh
    Here are the videos. The 665 was about broke in (half dozen tanks).
    The 681 only had about a half tank (couple heat cycles and retorqued cylinder bolts)
    I timed them twice and these are the numbers I got
    665
    1st cut 4.0 and 4.03
    2nd cut 3.7 and 3.75
    3rd cut 3.69 and 3.60
    4th cut 3.60 and 3.65
    681
    1st cut 3.0 and 2.90
    2nd cut 3.07 and 3.09
    3rd cut 2.94 and 2.96
    4th cut 2.81 and 2.74
    Here are the videos
    Solo 665 before putting on 81 cc kit (681):
    Solo 665 (now a 681):
    Now open for replies.. :D
  5. DexterDay
    Northeast Oh
    And for those who are worried about putting something back where it went? You can take pics along the way? Or before cell phones, in my early shop days, we were taught to use little pieces of paper and write down, what went where.
    Or in the case of cylinder head bolts, lifters, valves, or any other important wear fit part? Place in order in a cardboard template.
    Here I did a small example to show how you can organize parts.
    After doing several, you won't need to mark anything. You'll just be able to break it down, throw it all in a container, and put it back together :)
    And the last pic is the compression of the 65 cc jug. I want to give the new jug some time to seat before taking a reading.
  6. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Awesome saw dex :thumbs:
    I don't know much of anything about tinkering with saws, but it sure is fun to watch you guys do it. Very impressive results in the video :saw::saw::saw:
    $ooline, Kevin Smith and DexterDay like this.
  7. cgraham1
    cgraham1
    Nor Cal
    I've done a few Dolmar/Makitas myself, and find them pretty easy to work on. If anyone is hesitant to try this, don't be... With a few tools and a few hours, anyone can do a P&C swap on a chainsaw.
    Thanks Dex for the great thread!!
  8. DexterDay
    Northeast Oh
    Most people think they can't accomplish something like this? But it is much easier than most think. A few tools were needed but they were not expensive.
    Some of the tools I bought for this project were cheap! A 6" long t-25 torx in 1/4" drive was less than. $5 shipped!
  9. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
  10. SquareFile
    SquareFile
    somewhere
  11. Chvymn99
    Great Job, Dex! and some nice gains too...:yes:
  12. mdavlee
    mdavlee
    There's a decent difference in cut times.
    $ooline, clemsonfor and DexterDay like this.
  13. rookie1
    rookie1
    Nice job taking the time to make the thread Dex. I know it's a pain and time consuming to do. :)
    $ooline, clemsonfor, Chvymn99 and 2 others like this.
  14. JRSDWS
    JRSDWS
    Central Illinois
    I did the same upgrade to my 665 last week....using the same P/C kit that KLR sourced from Solo. The original plan was that I'd wait and follow this thread to do the conversion on mine, but I was antsy and Dex was buried at work.....sooo...I dove in anyway. KLR and Dex helped me through when I had questions....sometimes very newbie questions....but they were champs and answered without hesitation.
    Prior to this, all I had ever done is break saws down for good cleanings....never removed a cylinder let alone change a piston.
    Disassembly was simple....I take pictures for reference just in case. I pulled the intake boot and impulse line and left them....removing the jug by itself. I did rip the impulse line trying to get it off the cylinder barb and had to replace that. It was a simple, inexpensive lesson learned.
    I spent about 1.5 hours on it approximately total....messing with it over a few nights. I wouldn't say anything was particularly difficult at all. The circlips on the wrist pin can try your patients, but I fell into something that worked for me I guess. At first I thought compressing he ring to slide the cylinder down over the piston would be a pain, but it really wasn't....again....patience with a mind to learn and it went pretty easy.
    My saw popped on the 5th pull and I was elated. It felt good to do some outpatient surgery on my saw and be successful!! I haven't been able to put it in wood yet, but the difference is noticeable in the hands....torque feeling!!
    If anybody is thinking of such a task....do not fear. It's not that hard. Best of all, you area member of FHC with lots of awesome resources to help you. Membership has it's privileges!!
    $ooline, Cut4fun, Chvymn99 and 5 others like this.
  15. cory@owen
    cory@owen
    Time to stick it in something big. That'll tell the story.
  16. cnice_37
    cnice_37
    You guys always loctite the cylinder bolts?
    After checking squish will you consider a gasket delete?
    Looks like a nice clean saw to work on. I like that the intake boot easily (at least it looks easy) removes with the jug. I hate yanking on those things for fear of tearing.
    DexterDay, Chvymn99 and mdavlee like this.
  17. Aclarke
    Aclarke
    Santa Barbara, Ca
    Thanks for sharing!
  18. mdavlee
    mdavlee
    I use blue on them all just for good measure. Usually the stihls won't work loose but the husky saws can.
  19. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Dolmars will work loose also.
    $ooline and DexterDay like this.
  20. DexterDay
    Northeast Oh
    I only put some back on, because they had some on from the factory. All the Stihls I have ever worked on, never got any.
    As for the base gakset? I don't like to push my luck. The jug is pretty thin around the outer edges of the transfer ports. So I used the metal gasket that comes on the Dolmar 7900.
    KilliansRedLeo likes this.
