Baro damper
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Bob Blunt, Jan 3, 2016.
  1. Bob Blunt
    Bob Blunt
    upstate new york
    Does anyone use a Baro Damper on there wood stove? Good, bad Idea ?
    Woodsnwoods likes this.
  2. brenndatomu
    That's usually more of a wood or coal furnace (in the basement) thing, but no reason it wouldn't work on a stove. Any reason you wouldn't just use a manual damper? Baros cool the flue and can cause creosote issues unless you are burning really dry wood...and then even...
  3. Bob Blunt
    Bob Blunt
    upstate new york
    After all the great advice I disabled the baro damper. Because the stove had hot coals in it I couldn't remove the T portion of the baro damper so I removed the flapper part and capped it. What a difference it made in my stack temp, came up so much faster allowing me to shut the stove down sooner. Thank YOU all.
  4. brenndatomu
    I have a baro on my wood furnace, but don't like the creosote it helps to create, so I try not to use it unless the draft is not controllable with the key damper or real erratic due to wind. It is ready to go at a moments notice, but generally I keep it covered with HD aluminum foil, seems to work out pretty well
  5. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have an indoor wood furnace with a 40ft tall 8 inch diameter triple wall chimney. When I first fire it up, I will slide it over which holds it closed. After about 10-20 minutes I allow it to operate, but it is set such that it barely moves unless the wind is howling. I do not mind the slight leak by since the temps stay relatively hot and the air velocity decrease allows a better exchange in the stove. Slight balance act to ensure efficient combustion, efficient heat exchange, and maintain proper flue temps.
  6. Bob Blunt
    Bob Blunt
    upstate new york
    Thanks woods . Not far from cuse here.
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Cool. I live a little Southeast of the city, where is upstate for you?
  8. Bob Blunt
    Bob Blunt
    upstate new york
    south of Utica
  9. jdonna
    jdonna
    MN
    I experimented with one do to really strong draft especially on windy days, but I didn't like the room air being sucked up the stack, noticed more buildup of soot in the single wall than I liked. It was pretty fun to set the stack with my manometer and watch it stay rock steady.
    We went back to keeping a turn key damper in the stack and changing chimney caps. We are totally satisfied with the stove air control and the turn key as a backup.
    Backwoods Savage and Woodsnwoods like this.
  10. crzybowhntr
    crzybowhntr
    WV
    I use one on my wood/coal furnace as it helps keep my draft in check. Without it my draft is 3 times as much as the manufacture recommends. I mainly burn coal so I am not worried about creosote.
