Bar oil for life?
Discussion in 'The Wood Pile' started by Greg, Sep 28, 2016.
  1. Greg
    Greg
    was tired of paying a lot for decent bar oil, so got a barrel of pretty good viscosity stuff for $330, so 55 gallon drum gives me 6 dollar gallons. Now my buddies can bring their empties for cheap refills. IMG_3303.JPG
    Hammy, Dancan, Mag Craft and 13 others like this.
  2. Eric VW
    Always thinking!
    That's awesome, Greg! :thumbs:
    Hammy, NortheastAl, Chvymn99 and 3 others like this.
  3. papadave
    Now you don't need to wait for the $4.99/gallon sales.:whistle:
    Hammy, Fanatical1, Mag Craft and 7 others like this.
  4. Breechlock1
    Breechlock1
    Is it just oil in the drum? Or is bar oil, as in has the "tacifying agent" that makes it stick to the chain?
    Regardless, I like the idea and if it doesn't have it you can probably find it as an additive
    Hammy, NortheastAl, Chvymn99 and 2 others like this.
  5. Greg
    Greg
    It is bar oil. It is called triple tac I think. Compared it with the stuff I have been buying and this is much thicker. You get out my way I'll pour you a mug. ;)
  6. Jon_E
    Jon_E
    Southwestern Vermont
    I buy a case at a time, or more, every time bar oil goes on sale at Tractor Supply. It's $6 a gallon right now.
  7. Locust Post
    Good to have it on hand and that is a good price. I stocked up last year, TSC had it for about 6 then Menards came along with 4.50 if I recall correctly. I already had stocked up at TSC but couldn't pass up Menards price so I'm set for awhile.
  8. Greg
    Greg
    I've used tractor supply the last five year and buy 5 or 10 gallons every time they do their 6 dollar sale, but it doesn't do a very good job for me, especially from April thru Oct. Winter months its ok. But any kind of temps near 55-60 or more and the stuff is like cheap maple syrup
    Hammy and Backwoods Savage like this.
  9. papadave
    You do a lot of cutting.....having that much on hand is a great idea.
    I'd be dead before I could use that much. :picard:
  10. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Good deal, how will it work in the midst of the winter? Off the counter stuff is like sludge:dex:
  11. Greg
    Greg
    I will let you know, rare I cut in real cold, it will advise
    Hammy, Backwoods Savage and Chvymn99 like this.
  12. Backwoods Savage
    Does anyone still use kerosine mixed with bar oil in the winter months?
    Hammy, Locust Post and Woodsnwoods like this.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I just use the winter blend from stihl, or set the regular by the wood stove the night prior. I have also seen people utilize used motor oil in winter months. although I do not do this myself.
  14. Locust Post
    Never tried that, but after listening to Zap I did take some canola oil out when cutting in 10º, worked good.
  15. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    Welcome to the dark side.
  16. Locust Post
    If you are referring to the temperature, I have cut in -10º or colder as well. If I have the itch to cut, isn't much gets in the way......:saw:
  17. papadave
    A couple days ago, I was rummaging in the shed and found the quart bottle of Canola I bought at least 2 years ago.
    Still had some in it, and didn't look all funky. Next time I cut may find some of that in the tank.
  18. saskwoodburner
    saskwoodburner
    I was referring to the canola oil use actually.:thumbs: I'm a frugal guy, and find it works well.
  19. Mag Craft
    Mag Craft
    South East Wyoming
    On most pro saws the crank case and oil tank are side by side and are made of magnesium. Once the engine is hot the oil is going to heat up pretty good too.
    Now on a clam shell like a Husky 455 or the Stihl MS 290 the oil sits in a plastic case and does not share the same metal wall that a pro saw would, so it would not heat up as well. Then you might have to cut the oil with something to make sure it flows in really cold weather.
  20. Locust Post
    Here's a funny one....I used my jug of canola several times then the wife was baking one day and said I don't have enough oil. I said I have some in the garage, she thought I was joking in meaning some other type of oil. I went and looked and it had no saw dust dirt so she ended up using it up....I'll need to get another bottle if I need some. :rofl: :lol:
