Bar oil alternatives
Discussion in 'Chainsaws and Power Equipment' started by Sirchopsalot, Aug 18, 2021.
  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    So in scrounging, I'm on the look out for things I need, other than cordwood.
    Lumber to repurpose for example.
    But today I came across a source of clean hydraulic oil. Used, but generally clean. I got to thinking that that might replace bar oil..perhaps for winter use.
    What I know of bar oil properties is it's stickyness, whatever viscosity, and then it's burnability.
    Any thoughts experiences on bar oil alternatives?
    Sca
  2. B.Brown
    B.Brown
    USA
    I've used it, but, generally, mix it by supplementing it with a good brand of sticky bar oil. About 40% hydraulic and 60% good ole, sticky bar oil.
  3. amateur cutter
    Yes, use real bar oil & cut it with 10% cheap atf in the winter. Anything else is substandard, filthy dirty or grows mold when it sits, i.e. canola oil. Run real bar oil & save your bars & chains. My opinion/experience only.
    Edit: If you have an older Diesel engine save that hydraulic & mix it at about 10% to the ulsd modern fuel as pump & injector lube. Works great for that.
  4. Horkn
    I've heard of people using hydro oil for b&c oil. Also vegetable, canola oil, and motor oil too.
    I've never had to use any of these though.
  5. amateur cutter
    Don't unless it's a true emergency. Only thing I've subbed that worked well was 75W140 gear oil. It's likely better than bar oil, but about 2X cost.
    Chaz, TurboDiesel, Screwloose and 4 others like this.
  6. Horkn
    Understood:yes:
    Chaz, TurboDiesel, Screwloose and 3 others like this.
  7. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Why? Just why?
    At the end of the day bar oil isn’t that expensive and if you’re using 100’s of gallons you should be making good money and bar oil should be a very small percentage of your overhead.
  8. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    I use full synthetic or semi synthetic motor oil for bar oil.
    It lubes SOOO much better than bar oil ! It does sling off a little more, but it pumps real easy in the cold. I generally try to find some on sale or @ Costco. In the summer, bar oil is fine. But generally I don't do much cutting in the summer. If I had a source of real cheap/free hyd oil. I'de run it in the lube tank on my band mill.
    I use used synthetic motor oil as a general purpose lube on the mill. The travel/power feed chain , log dogs and lots of turn screws to keep moving freely.
    I change motor oil in the generator every 100 hours or less. It only holds 14 oz. But it adds up. And the vehicles. I get a good amount of used motor oil.
    Chaz, Camber, Screwloose and 3 others like this.
  9. buzz-saw
    buzz-saw
    Ct.
    Nope ; not me.
    I will stick with bar oil.
    Even cheap bar oil rather that used hydro oil.
    I can buy good bar oil for under 10 dollars a gallon and a gallon cuts a pretty decent amount of wood so I myself wouldn't even consider anything else.
    But that's just me.
    Others might have different thoughts and that's just fine too but I spent good money on good saws and to try and save a few bucks that way just isn't my thing.
    Chaz, BCC_Burner, Screwloose and 11 others like this.
  10. Sirchopsalot
    Sirchopsalot
    medium city in CT
    I had an old 12 valve once, with the idea I'd make my own fuel. Never materialized as we were apartment dwellers at the time, and i figured they'd frown on fuel making in my basement. But someday.
    Sca
    Chaz, Screwloose, Horkn and 3 others like this.
  11. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Because there is an availability of waste, and I have access, and I wondered.
    Sca
    Chaz, fox9988, Screwloose and 5 others like this.
  12. The Wood Wolverine
    Alternatives do not have a tackifier to help it stick to chain. Vast majority flings right off the tip, then where it's needed most, it's lacking compared to stuff designed for saw use. The more tack, the less oil you have to pump. Most saws today don't flow enough as is. It's your equipment so...
    I've milled with Mobil DTE. Roached a nice 37" Windsor bar. I learned the hard way.
  13. Screwloose
    Screwloose
    If it's a continuous source consider a waste oil burner. Otherwise like was said a gallon of bar oil cuts a lot of wood. And the cost of fixing a saw buys a lot of bar oil.
  14. BCC_Burner
    BCC_Burner
    Marble, CO
    Holy cow, where?! Even no-name brand bar oil is $20-25/gallon here. Stihl stuff is closer to $30.
    Chaz and OldJack like this.
  15. The Wood Wolverine
    Wow!! We buy it on sale at Tractor Supply Co. for usually 2 1 gallon jugs for $10.
    amateur cutter, Chaz, Ohio and 2 others like this.
  16. chris
    chris
    SE WI
    black max b&c oil at wally world is around 11/gal
    amateur cutter, Chaz and Screwloose like this.
  17. MikeInMa
    Off their website just now
    amateur cutter, Chaz, Ronaldo and 2 others like this.
  18. Ronaldo
    Ronaldo
    Exactly......no reason not to use actual bar oil. Just my opinion.
  19. Camber
    Camber
    Montana
    Bingo! I found a almost full 55 gallon drum of synthetic diff oil at a auction for 10 bucks. Stuff is great. Flows beautifully in -20 weather. I agree, there is no need to use anything but bar oil, if you are only cutting a dozen cord or so of firewood a year. If you are a faller however, you need to keep overhead down as much as possible right now.
    amateur cutter, Chaz, B.Brown and 4 others like this.
  20. bushpilot
    bushpilot
    Eastern Washington
    I get bar oil for about $14 for 2 gallons. But that said, I would consider cutting it with something cheaper if I had it, especially for winter. I'd start with maybe 3 parts bar oil to 1 part of the other, and work from there.
    I'm not cheap, I am frugal. :p
    amateur cutter, MAF143, walt and 2 others like this.
