Bar Mount Conversion
Discussion in 'Chainsaws and Power Equipment' started by Eric Wanderweg, Feb 7, 2024.
  1. Eric Wanderweg
    First off, thanks to Ernie G for selling me these 2 bars last week :handshake: I noticed he had them in the classifieds for months with no takers, so I decided to see what I could do with them. These 20” bars were the D007 mount style, off of Poulan saws. I was hoping to run them on my Husqvarna 61, which has a D009 mount. From my research, the oil holes line up and the chain adjuster holes work (albeit they’re larger) The biggest difference is the slot size for the studs. On a D007 it’s 0.5mm (0.020”) wider. Not being one to just run it that way, I milled out the slots oversize and added a slotted step. Then I made inserts that were a light press fit into the bars. That’ll solve the slop issue. While I was at it, I re-dressed the rails, and figured these were the perfect guinea pigs to try my new homemade rail closer tool on, which will probably be later this week. The last thing I’m going to do before running them is to strip them completely and give them to a buddy to powder coat them. Might as well give them some kind of aesthetic appeal.
    The bars as advertised:
    Surface rust removed, slots milled and inserts made:
    653ED2D9-940F-4009-A329-03CD00FBF30F.jpeg 823A04C1-8839-4508-AEDE-6F4B534503D2.jpeg
    Inserts pressed in:
    9CA070C1-DE89-4293-9064-DCC44EF7616E.jpeg E22309BA-579E-42D4-BA48-663D685F22DC.jpeg
    My homemade rail tool:
  2. Eric VW
    Curious…
    :sherlock:
  3. Ernie G
    Ernie G
    Wyoming pa
    Well I'm glad you're making good use of the bars..they look good so far !
    Thank you !
    Ernie
    John D, Horkn, brenndatomu and 3 others like this.
  4. The Wood Wolverine
    Very nice Eric!
    I once borrowed a local forum guys homemade rail closer. Didn’t work for me. Be interesting to see if you get good results. I have a 37” Windsor Speedtip bar with a V’d groove. Rails won’t budge.
    John D, Horkn, brenndatomu and 2 others like this.
  5. Eric Wanderweg
    I know if the bearings ride too low, they’ll be pinching on the solid part of the bar and you can crank up the tension all you want but the gap won’t close. I didn’t have any thinner bearings on hand so I put a taper on the outer race of these ones, so it should only pinch the rail section. We’ll see… I fixed the rails on the 18” bar I had for this saw using a narrow vise and just kept doing one section at a time, but it was tedious and time consuming.
  6. The Wood Wolverine
    Upon recommendation, I put a thin piece of sheet stock in the groove and beat rails w/ a hammer. No dice, nothing worked. Hope to someday find someone with a groove grinder, I'd have my son put some weld in there and then re-grind. Know anyone w/ a Barshop?
    Horkn, brenndatomu and RCBS like this.
  7. RCBS
    RCBS
    Over here
    The Chainsaw Guy's shop can probably fix it. Shipping may be offensive though.
    Myrtle Creek Saw Shop | Saw Shop
  8. The Wood Wolverine
    Yep. I know Shaun Carr can do it, but I don’t wanna spend more than it’s worth on shipping both ways. Need someone kinda local.
    I think I heard the chainsaw guy passed away?
    Horkn, RCBS and brenndatomu like this.
  9. RCBS
    RCBS
    Over here
    Nah he's still going. He puts out videos under WestCoastMuscleSaws now. I have to laugh...you can tell he misses the shop. He 'retired'. I basically cut my teeth on chainsaw knowledge by watching Rich's videos over the years. So much good information contained. I realize many of those videos were actually advertisements to sell second hand saws, but some of the videos have near priceless mechanical/anecdotal information to them. He also has the absolute coolest shop tools.
  10. Eric Wanderweg
    I always thought it would make more sense to have a bar with removable rails. Once they get clapped out, replace them and not the entire bar, and no fiddling around with trying to close up the groove width. 3/16” long #8 or #10 flat head screws would work to secure them.
    Crude sketch:
    John D, Horkn and brenndatomu like this.
  11. Eric Wanderweg
    A little update. My coworker is finally getting around to powder coating these bars for me. One is obviously going to be black and the other one with the funky swirls got clear coated. Can’t wait to run them!
    73A8B0F9-496D-468B-8F2F-84C801C20F11.jpeg DFA9F735-929A-455C-AA80-EB3322391AC5.jpeg 93484950-998E-4F2F-9C4A-EE086B437D7F.jpeg 36B579BB-B286-47DA-BBD0-EAFD3F3BC857.jpeg
    MikeInMa, Chud, John D and 8 others like this.
  12. The Wood Wolverine
  13. Ronaldo
    Ronaldo
    That's neat. Do you expect them to last longer than a regular painted finish?
    Eric Wanderweg likes this.
  14. Eric Wanderweg
    That’s the hope anyway. The bond is supposed to be stronger than regular paint so we’ll see how it holds up.
  15. Eggshooterist
    Eggshooterist
    Erff
    Ronaldo and Eric Wanderweg like this.
  16. buzz-saw
    buzz-saw
    Ct.
    Nice work Eric.
  17. brenndatomu
    Too purty to use now...;)
  18. John D
    John D
    Syracuse ny
    Very nice eric
  19. The Wood Wolverine
    Keep the chain really sharp and it should keep the bar temp low enough to last a good bit longer than prying up on a dull chain and making the rails screaming hot. The clear coat on my Sugi’s is still there for the most part and I’ve been using them for years.
  20. MikeInMa
    Nicely done! :salute:
    eatonpcat, John D and Eric Wanderweg like this.
