Bar and Chain Oil
Discussion in 'Chainsaws and Power Equipment' started by NYCountry, Nov 6, 2018.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    Just curious as to what you hoarders use for your bar and chain oil. I only have used stihl bar and chain oil for my saws. Is it ok to use other brands or should I stay with what I always have used for my stihl saws..thanks for your thoughts
  2. papadave
    I use the stuff from TSC when it goes on sale.
  3. mat60
    mat60
    ME
    Been wondering about this also.
  4. Maina
    Maina
    Maine
    I usually buy mine at NAPA.
  5. Fanatical1
    Fanatical1
    I buy mine at Menards when it goes on sale. I think it was $5.99/gallon. I like it too....
    I bought 3 gal last time, so I'm set for a while...
  6. Breechlock1
    Breechlock1
    I use Stihl in the grey jug. It doesn't stink like heavy weight dino oils that the cheaper b/c oil does. Feels cleaner, I can see through it. It's worth the $14/gallon.
    I do use cheap stuff in my old 80s saws.
  7. NYCountry
    NYCountry
    Mohegan Lake NY
    Do you use a different blend for the winter
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2
    I buy summer and winter weight....never a problem !
  9. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I do. My Husky saws like it alil thinner :)
  10. Breechlock1
    Breechlock1
    Not for my modern saws. The grey jug is gtg year round. I also keep it in the truck. Between that and a warm saw it's fine.
    I do use winter bkend in my 298xp and 281xp. It is hard to find the early 80s style worm gears for for t those two saws. Especially the brass worm gears
  11. Jon_E
    Jon_E
    Southwestern Vermont
    Bar oil from Tractor Supply. $7 a gallon on sale, sometimes $6 if you're lucky. I stocked up a year or so ago, bought 6 gallons and am still using it. Noticed that they also carry a winter weight oil but I have not tried it.
  12. RCBS
    RCBS
    Over here
    I'll use anything that has a name brand on it. Past few years it's been Husqvarna brand during summer, (been buying at the Bunyan show for $8/gallon) and Jonsered branded winter weight from TSC for the winter. I think I grabbed 4 gallons when it was on sale a few years ago and still have 1-1/4 gallon left. IMO, the winter weight does make a difference. There is noticeable difference in viscosity/thickness. The Jonsered stuff pours easy and lubes good below freezing.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I use Stihl oil with the proper season. Why save $10 in an MS880 and wreck parts far more costly than the oil. My dad ran used motor oil in his old mcculloch for years and it never skipped a beat.......
    RCBS, Barcroftb, Screwloose and 5 others like this.
  14. Will C
    Will C
    New York
    I use Husquvarna that I pick up for $7-8 a gallon at the NYS Woodsmen's show-pick up a case of winter and a case of summer weight every summer.
    RCBS, Barcroftb, Screwloose and 4 others like this.
  15. huskihl
    huskihl
    I get the FVP stuff from Menards on sale for $5 per gallon. Really tacky. In winter I cut it with a cup or 2 of mineral spirits or diesel fuel.
    RCBS, brenndatomu, Barcroftb and 5 others like this.
  16. mike bayerl
    mike bayerl
    i do this, it works
  17. amateur cutter
    This answer except I cut mine with Auto trans fluid because I always have that around. I go through 10-12 gallons a year & haven't had any problems with bars & chains or oilers.
  18. huskihl
    huskihl
    Plus pretty red color:cool::p
  19. In the Pines
    In the Pines
    I use Husqvarna. I've wondered about the cheaper stuff but never used any yet.
  20. bushpilot
    bushpilot
    Eastern Washington
    I use the cheapest stuff I can find, generally about $6 / gal.
