At What Stove Top Temperature Do you Start to Worry?
Discussion in 'Modern EPA Stoves and Fireplaces' started by woody5506, Dec 27, 2017.
  1. woody5506
    woody5506
    Upstate NY
    I routinely get my stove top up to 700+ before cutting the air all the way, or nearly all the way off, which lets it drop into the 600 stove top range. It's a PE T5 which is a steel/cast iron jacketed stove. Steel stoves are able to take higher temps better or so I've heard, but I know the temps I routinely run in this stove probably wouldn't go so well with others. I've only ever seen parts inside the stove start to glow red once or twice, which to me was an obvious over fire but didn't take long to remedy once the air was cut off.
    This is still a pretty new stove. I got it installed last January, burned from then on up until May. I run it daily now, nearly 24/7. I see no signs of damage to the baffle or any other internal parts. No cracks in firebricks. There is a very slight bow/warp to the baffle which is normal for the PE stoves.
    I guess my question is, am I pushing this stove too hard by routinely getting it up to 700+ before knocking it down? I see some people getting worried when things go past 600. I consider that a cruising temp. And as the title asks, when do you start to worry about overfiring?
  2. LongShot
    LongShot
    New Mexico -Jemez Mountains
    I start cutting the air back at 600 or so, and cruise at 500. Could probably cruise higher, but Mama starts to sweat! :heidi:
  3. Backwoods Savage
    Stove manufacturers will normally a rating for their stoves. For example, our Woodstock Fireview says to not go over 700 stove top, but we've heard many folks who run them hotter. However, this always brings a caution especially with cast iron wanting to warp.
    Most steel stoves should be able to handle 800 but some are rated lower.
    So to answer your question on if you are running your stove to hard. I highly doubt that. As for worrying over 600, methinks that is being just a bit too cautious as 600 gives you some great heat and that is what the stove is designed to do and that is what we want when we buy the stoves.
    Somehow it never ceases to amaze me how folks can install a huge oil or gas furnace that runs a whole lot hotter than a wood stove and not worry a bit (perhaps because it is unseen?). Yet they constantly worry about a wood stove. I think it is really a case of they have read or heard about a house burning down and they had a wood stove. But that does not mean all houses are in danger! After all, I know of many people how have died in car accidents...but people still go on driving around...
    Chaz, leoht, FatBoy85 and 5 others like this.
  4. chris
    chris
    SE WI
    due to a scary overfire many years ago I start sweating at temps over 600 and it ain't from the heat.
  5. woody5506
    woody5506
    Upstate NY
    I think reading wood burning forums puts my mind at ease in some ways, and makes me nervous in other ways. Reading everyone's horror stories makes me think a bit more! The whole stove top thing doesn't make me too nervous, and even an overfire isn't a big deal in my stove because the fire is so easy to control with the air control. But it seems that a great cruising temp for some makes others totally paranoid. I think my stove purrs at 600-650.
  6. justdraftn
    justdraftn
    On the road
    Where is you thermometer placed?
  7. Screwloose
    Screwloose
    Dang !!!! If I hit those temps on my stove top (old faithful Nashua) we'd be in our undies with the windows open !!
    Thor likes this.
  8. woody5506
    woody5506
    Upstate NY
    The actual stove top with the trivets swung out. Slightly left of the flue.
    OhioStihl and justdraftn like this.
  9. justdraftn
    justdraftn
    On the road
    That's where mine is, too.
    So, if the stove top is 650F.....
    what is the temp of the actual flue gas?
    I found this:
    The normal operating temperature for the flex liner is 1000°F (540°C) in the United States and 1200°F (650°C) in Canada.
    It has been tested for abnormal intermittent temperatures of 1700°F (927°C) for oil and
    2100°F (1150°C) for solid fuels, should temporary appliance malfunction occur.
    I would guess that even at stove top 700F, flue is still way under 2100F.
  10. bushpilot
    bushpilot
    Eastern Washington
    I keep it in the white and out of the red (outer band, photo below). At the current position it IR'd at 510, and the bottom of the white "Target Zone" is about 300-350 IIRC. I don't know if I have measured the top of the white yet, but I would guess it is about 800. Any time my stove has been that high has been short lived, such as restarts on hot coals. I run my flue below 900.
    Englander does not give a max temp for the NC-30, but says that if anything glows, it is being overfired. Nothing but the burn tubes glow at my max temp, so my simple method works out for me. Just keep it in the white arc as much as possible. Thermometer is placed on the hottest point on the stove top, which for my installation is right in the center of the angle on the top.
    woody5506 likes this.
  11. Highbeam
    Highbeam
    I run my plate steel stove pretty hard. The manual doesn’t want external parts to glow but it is totally normal for the burn tubes to glow brightly even at relatively low stove temperatures.
    I purposely get the stove to 700-750 and adjust the intake control to keep it there as long as possible. All the while my single wall flue temps stay under 400.
    HDRock, papadave and Backwoods Savage like this.
  12. BDF
    BDF
    My stove top temp. rarely gets to 600F and it has never seen 700F. Just my opinion but I would not allow any steel, mechanical parts of the outside of a woodstove to sustain 800F; steel begins to fluoresce by 900F, and it loses a lot of its strength as well as beginning to corrode very rapidly at those temperatures.
    Besides that, just my own personal opinion but if one needs to run stove top temps. that high (sustained at 700F and higher), a bigger stove is needed or the window(s) should be closed. ;):whistle:
    My stove spends most of its time with the STT in the 3XX to low 4XX F range. As my house is not properly closed-in, I require more heat than normal and so with temps. dropping to single digits, the STT has been above 500F recently and I would not hesitate to get into the 600F range, although I would probably stay below 650F, at least sustained temps. If the stove could not keep up with the house at that point, I would supplement with central heat (oil- fired boiler) or make some effort to seal up the worst parts of the outer shell of the house.
    Brian
    M2theB likes this.
  13. woody5506
    woody5506
    Upstate NY
    Here's where things are at right now. I got home, cleaned all the ash out, reloaded with kindling and 3 small splits. Stove hit over 600 and I choked the air down half way. This is within 30-40 mins with those 3 splits. 20171227_165842.jpg 20171227_165851.jpg
  14. Highbeam
    Highbeam
    On just those couple of splits? Cool. What happens when you fully load to the roof?
    I run my noncat at max output because I need the heat and I need more heat. I wish they made bigger stoves but the nc30 is about it and no wood furnace is clean burning enough to b legal in Washington. Not even the kuuma!
    This is in the shop and the only source of heat. Luckily my home is much smaller and can be easily heated by a cat stove on low or medium output.
  15. brenndatomu
    I get that maybe Lamppa hasn't spent the money that is takes to grease the WA. politicians pockets enough to get the VF "WA. approved"...but the test results that I seen, VF100 beats NC30 hands down as far as emissions go...you find something otherwise?
  16. brenndatomu
    As far as temps go...I kinda watch the fire...if things are rolling good and temps climbed up pretty quick after reload...I will start to close things down at 600...STTs will continue to climb as the secondary burn settles in on "cruise" mode...and I expect it to hit 700* normally if I have the stove loaded up good...sometimes I even see it peak at 800*...which doesn't bother me much, but I will begin to monitor things more so at that point...ideally I don't want things getting too much hotter than that...but as previously mentioned, I wouldn't get too terribly excited unless I saw something external start to glow...then I'm on full alert!!
  17. woody5506
    woody5506
    Upstate NY
    The manual states not to load above the firebrick which seems stupid to me unless you clean out ash/coals daily. I can get that thermometer maxed out pretty quick with a full load. Usually I'll let it creep into the red or around 700 then cut the air. Then it hovers around 600...then I go to bed.
    papadave likes this.
  18. OhioStihl
    OhioStihl
    Southern Ohio
    The T6 runs anywhere from 450 to 600.
    The Progress runs in the 450-500 range.
    If the temps are 50-100 past those temps I start to get concerned.
  19. bushpilot
    bushpilot
    Eastern Washington
    I think most people load above the firebricks on the NC-30, I certainly do. I think a "high" load is better than a "wide" one, if you are not loading full.
  20. Highbeam
    Highbeam
    No furnaces have passed the required cordwood test for furnaces in wa. Not that they couldn’t but they haven’t. A few boilers have been approved.
