At the Grinding Bench
Discussion in 'Chainsaws and Power Equipment' started by Reloader, Mar 6, 2026 at 12:45 PM.
  1. Reloader
    Reloader
    NW Oregon
    Still not good at getting things sharp but I can usually get them good enough to cut a bit of firewood.
    Sent from my iPad using Tapatalk
  2. T.Jeff Veal
    Good video. Just watch your angle settings, use a lite touch, (just kiss the cutter) and if chain is bad dull, make multiple passes until it's sharp.
  3. brenndatomu
    Oh, you don't want to take it all off in 0.001 seconds, like Bubba at the saw shop does?! :hair:
  4. Eric Wanderweg
    :yes: To the video.
    One other tip I'd like to add is to make sure the chain is clean before you start grinding. Any residual bar oil can make the wheel "glaze over" (the pores will become clogged with swarf/debris, it will take more effort to remove metal and generate more heat in the process) Keeping the grinding edge fresh with a dressing stick or diamond file goes a long way.
    eatonpcat, John D, Screwloose and 2 others like this.
  5. wiguy
    wiguy
    Wisconsin
    That is some serious grinding, the ‘angles’ mostly accounted for.
    My current preferred method is to put the chain in a bench vise, then do each tooth with a quality round file. I have reading glasses and at least good ambient light. I’m not saying I’m at the utube instructional level, but I do ok. I’ve been touching up the rakers more lately also, taking them down. Speaking of rakers, different ‘preferred’ reductions related to softwood cutting or hard. I prefer a good bite for the tooth.
    I have used some of the crank wheels & jig clamped to the bar, seem to come back to the round files. I was on a run watching some of the utube guys giving instructions a few months ago. One can usually pick up a tip or 3 with many videos.
    eatonpcat, John D, Screwloose and 3 others like this.
