The quest still continues for a smaller wood stove..This one from Vermont Castings has caught my eye: Starting at $1,249: Model Specifications Aspen C3 Appliance Width: 16" Appliance Height: 25-1/16" Appliance Depth1: 24-1/2" Peak BTU/hr Output2: 35,200 Heating Capacity3: 400 - 1,200 sq ft Maximum Burn Time4: 10 hrs Firebox Capacity: 1.25 cu ft Recommended Log Length: 16" Efficiency5: LHV 81%, HHV 75% Emissions: 1.9 grams/hour 1 Appliance Depth includes entire unit including depth of firebox and extension onto hearth. 2 BTU: 1st hour output uses high burn efficiency number. BTU will vary depending on the type of fuel used and moisture content of the fuel. 3 This is a general guide, see your local dealer for help in determining the product that best suits your heating needs based on climate, home efficiency, location of the heater, and air movement in the room. 4 Actual burn times will vary based on how the appliance is operated, load size, moisture content and type of wood used. 5 Weighted average LHV (Low Heating Value) & HHV (High Heating Value) efficiencies using data collected during EPA emissions test. HHV efficiency over 75% qualifies for the 2021-2023 Federal Tax Credit. Heat output will vary depending on the type of fuel used. The flame and ember appearance may vary based on the type of fuel burned and the venting configuration used. Actual product appearance, including flame may differ from image shown. Refer to the owner's manual for complete clearance requirements and specifications. Product specifications and pricing subject to change without notice. For testing and listing information please refer to the owner's/installation manual. *For select products: Heating capacity to be used as a guide only. See your local dealer for help in determining the product that best suits your heating needs based on climate and home efficiency. †For wood-burning appliances: Actual burn times will vary based on how the appliance is operated, load size, moisture content and type of wood used, and installation. Specification Images Front View Side View Top View Vertical Venting 6" Single Wall Pipe Vertical Venting 6" Double Wall Pipe Compact yet strong, the Aspen® wood stove adds warmth and style to intimate spaces. When every element is meticulously crafted, quality speaks for itself. With no manual controls, this is the simplest stove you will ever operate. Continuous Combustion Control™ (C3) Technology automatically optimizes heat output and efficiency throughout the life of the burn Top plate cooking surface for the stovetop chef Up to 10 hours of burn time from each load of wood Perfect for small and mid-size spaces PLEASE GIVE ME YOUR THOUGHTS..THANKS
I have one of those stoves. It's very small and moderately effective for a small house like mine. See my review here.2020 Vermont Castings Aspen C3
