AS Damper
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marshel54, Apr 7, 2025 at 7:39 PM.
  1. Marshel54
    Marshel54
    The inlet air dumper lever on my AS started not staying up. Flame acted like the damper was fully closed. I took the back off and the nut for the damper mechanism was loose. I tighten it up and the lever felt normal,
    Is there anything connected to the damper on the back side? I can't run the stove until I get the glass that is on order.
  2. Flamestead
    Flamestead
    Windsor County, VT
    The AS has the disk style damper, doesn’t it? I don’t know that I have pictures, but will check. Extremely simple mechanically, as I recall.
    brenndatomu likes this.
  3. Flamestead
    Flamestead
    Windsor County, VT
  4. Marshel54
    Marshel54
