Are 034, 034 super and 036 body parts the same?
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, May 18, 2014.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    My 034 super looks like it's been through a nuke blast and back... A friend of mine has 2 saws 036 and 034 that are junk but between the two I can get a lot of good body parts. Will they be the same?
  2. Jon1270
    Jon1270
    Pittsburgh, PA
    You can swap them around, but they're not all identical. The 036 recoil cover looks quite a bit different from the 034. The 036 sprocket cover is magnesium rather than plastic. If you want to use an 034 engine shroud on an 034s / 036, you'll have to trim an interior rib to clear the larger cylinder.
    Pallet Pete likes this.
  3. Pallet Pete
    Ovid
    So 036 and 034S are the same?
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    I think the engine shrouds are, but not everything. I've had an 034, 034S, 036 and 036 pro, but not all at the same time so I haven't been able to do side-by-side comparisons.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    Yes. They use the same cylinder. The 036 standard and the 034 Super are the exact same. Even the recoil cover was round and plastic. The 036 Pro is when the switch to Mag recoil cover was made (both will still mount to either one).
    Yours is a Super? Correct Pete? Then just stay away from the cylinder on the 034 and you should be fine. The carb, air filter, and air filter cover are different from Pro to standard 036.
  6. DexterDay
    Northeast Oh
    And the top cover shroud on the 034 is different. . As Jon said.
  7. Pallet Pete
    Ovid
    Thanks fellas I'm gonna pick up the saws or ( parts I should say ) tonight then.
    Grizzly Adam likes this.
  8. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Thanks guys, great info. I've got that 034 super that Jon mentioned.
