Any idea that this pipe was for?
Discussion in 'Everything Else (off topic)' started by Unicorn1, Dec 29, 2020.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    Hello FHC, trying to solve this pipe mystery in my shop.
  2. Eric VW
    Waste oil tank was my first guess.
    Do you own or have access to a bore scope?
    mat60 and M2theB like this.
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    Hoping it's not a tank but very possible. Most tanks have threaded neck/caps, and the neck is filled with dirt so I'll have to poke around and vacuum it out.
  4. yooperdave
    Maybe an abandoned fuel or holding tank? I have heard people filling them with sand/dirt once they quite using them in order to satisfy regulations and prevent the cost of removal of the tanks.
    mat60, MikeInMa and M2theB like this.
  5. M2theB
    M2theB
    Central Massachusetts
    No idea, but I will say I enjoyed the video and commentary
    Dirty windows clinched it for me as a movie set with the front moving in.
    what I do see also is that it looks like that flange is cast in after the original slab was placed. To me that would say someone had replace the original conduit going down, or it was cut in and is just meant to perc what ever was going down.
    Concrete doesn’t look oil stained to me.
    mat60 and Jack Straw like this.
  6. Creekin
    Creekin
    Manitoba
    Just a stab in the dark, wonder if its something that they would have used as a mounting base for some type of fixture base like a small crane or shop equipment stand?
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Maybe part of an old hydraulic lift system, we had that at the vocational school I used to work for.
    mat60 and yooperdave like this.
  8. sirbuildalot
    sirbuildalot
    Mass
    Usually underground tanks would have a fill pipe and a vent pipe. If it was an old tank that they filled it would seem odd to go through the trouble of unscrewing the fill pipe to put in that sleeved pipe plug you have. I agree with Creekin and Jack Straw, it appears to be some some of mounting base for a piece of shop equipment. I’d guess that square of concrete around the pipe is deeper/thicker than the rest of the concrete floor.
    mat60 and basod like this.
  9. brenndatomu
    My guess too
    Stinny and mat60 like this.
  10. M2theB
    M2theB
    yup, could be a davit base
    Stinny likes this.
  11. billb3
    Rather heavy gauge pipe for a tank, plus it's pretty easy to shine a tube down a hole to see if it is anything more than just a hole.
    A davit or floor stand would need a rather heavy pipe. Was the stove a heater or a forge ?
  12. Unicorn1
    Unicorn1
    Amarillo, TX
    M2theB likes this.
  13. Highbeam
    Highbeam
    Oh gawd! Don’t let that kid step on those nails sticking up.
    M2theB and mat60 like this.
  14. Unicorn1
    Unicorn1
    Amarillo, TX
    Old pictures and he was the keeper of the shop keys.
  15. Sirchopsalot
    Sirchopsalot
    medium city in CT
    My dad built in the 70's, and has floor drains in garage and shoppe. Look much like these. They drain under the floor to the outside.
    Sca
