Anti-kick back chain vs non....
Discussion in 'Chainsaws and Power Equipment' started by Joe P, Nov 13, 2020.
  1. Joe P
    Joe P
    Wisconsin
    Hi Guys -
    I'm running a 450 Rancher with 20" bar as my workhorse saw. I'm soon to be upgrading to a 572 built by Huskhil with a 32" bar. (WHEE!) All my saws in the past have had the standard low-kickback chain that would be purchased from the local hardware store.
    It doesn't appear that low-kickback chain is available in loops for the bigger saws, and not really looking to buy reels of chain and make my own. I never understood how that worked until I started looking at chains and understanding the differences between chisel/semi-chisel etc
    I'm curious what most people are using? I've never used a standard chain (not low kickback) and curious (and a little nervous) what kind of difference I'll see, other having to be more conscious of the upper quadrant of the bar.
    Horkn, brenndatomu, Mag Craft and 5 others like this.
  2. M2theB
    M2theB
    Central Massachusetts
    I have the saw your about to have.
    Have fun. The difference between that and your 450 should be readily apparent :bug:
    ive got a full chisel, full compliment series on it now on a 24”
    Planning to go to 20”, same chain but change to a 8T rim sprocket, for a while anyway.
  3. huskihl
    huskihl
    I would go to a Husky or Stihl shop that carries a good selection of chain, or can make you one from a roll, and try some full chisel non-safety chain with your 450 before I get the 572 to you. Just to give you a chance to get used to it
    Josh Stephen, Slocum, Horkn and 13 others like this.
  4. JimBear
    JimBear
    This ^^^. Good solid, sound & safe advice.
  5. The Wood Wolverine
    Full chisel is shaped like a 7 and semi-chisel is a ? rounded shape.
    That rounded shape of semi really lasts longer if you are cutting dirty wood. I don’t use it at all because the full chisel cuts much quicker. You just need to be much more careful you don’t touch dirt.
    The safety chain compared to non, will not be a huge difference, unless you had the wild stuff like this:
    It will just cut more aggressively, and if you put the top 1/4 of the tip where it shouldn’t be, you will get the bar slung straight up and or back (kick back). Practice safe cutting techniques and it’s a nonissue.
    When you get the ported 572 the difference will be tremendous, so I’d take Kevin’s advice and get a loop of the non safety and run it on your 450. You’ll like it.
  6. Spencer
    Spencer
    Indiana
    Any type of chainsaw chain and bar combination can bite you. I had my little top handle saw kick off a spring pole once and bite my toe. The chain on it doesnt even look like it would cut because the teeth are so rounded over and there are like 3 humps in between teeth to keep it from kicking.
  7. sirbuildalot
    sirbuildalot
    Mass
    I use full chizel on all my saws. As noted previously it cuts quicker but dulls easier.
    Horkn and amateur cutter like this.
  8. Joe P
    Joe P
    Wisconsin
    thanks Guys -
    called the local shop, they have it in stock so I'll take a swing in there and get a semi and full chain for the rancher and give it a go this weekend. Who would have thought there was so much to learn just to make some firewood!! :)
    RichE23ACR, Horkn, Yawner and 6 others like this.
  9. The Wood Wolverine
    The only negative is, you become so productive with a ported saw and stupid sharp chain, the saw time is greatly reduced, which is the best part of hoarding. :saw: Well, to some of us it is (everyone with a ported saw at least). :dancer:
  10. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    :woodsign::woodsign:
    Your learning curve is just getting started. These folks will teach you more about firewood than you thought there was to know. :saw::axe::tree::stacker::campfire:
  11. tamarack
    tamarack
    paulina oregon
    Ported 572! Your gonna love that. 32 inch bar? You must have some big trees to process. Yes you will notice a huge difference using full chisel vs. saftey chain, be careful.
  12. Mag Craft
    Mag Craft
    South East Wyoming
    I use chisel chain on all my saws. I have never had a saw kick back on me and I am always very aware of where the bar tip is at all times.
    Like others have said it is just a matter of forming and practicing safe procedures. You will not have a problem and will do well. Great saw by the way. Congrats.
    amateur cutter, JCMC, Horkn and 4 others like this.
  13. buZZsaw BRAD
    Aint that the truth!
  14. Joe P
    Joe P
    Wisconsin
    Yeah, I got a couple of big old dead standing oaks that are all of 30" across that have to come down. I figure I can always get a shorter bar if necessary. The other advantage is don't have to bend down as far, which makes my back happy. Buy once, cry once.
    LOL, wife said, lets burn wood. It'll be fun she said. We'll save money she said.. It sure is fun. Don't know about the saving money part yet. :)
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Wait until you need another saw, then another. Throw in a splitter, tractor, pickup, trailer and the list is endless. At least for me this is how it went.
  16. JimBear
    JimBear
    Truth !!!
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    On my Makita 36V I use an oregon low profile anti-kickback chain. 3/8" pitch, .043 gauge, 14" bar, 52 links.
    On my Stihl 028 gas I use a Stihl Rapid Super (non-low profile, non-anti-kickback) chain. .325" pitch, .063 gauge, 18" bar, 74 links.
    I can definitely tell that the bite on the Stihl is a lot more noticeable. I'd say it's probably a combination of the difference in tooth, more power coming out of the Stihl saw, and the wider kerf/cut of the Stihl. I'm a firewood beginner too (just got the Stihl a few weeks ago, first gas saw ever).......and I can feel the Stihl pull into the wood more aggresively.
    But man I really do enjoy the way it rips through the wood!
    amateur cutter, Horkn, ErikR and 3 others like this.
  18. JRHAWK9
    JRHAWK9
    Wisconsin
  19. The Wood Wolverine
  20. Joe P
    Joe P
    Wisconsin
    LOL - the more I read, the more I've learn.... In researching chains, I found a little unknown fact (to me anyways), that I'm supposed to replace my sprocket on the chainsaw. HUH? According to Oregon, every couple of chains!! RUH ROH RAGGY, I'm still running the original from 2014. I've cut a LOT of wood with this thing. I supposed I should crack that sucker open and see what I have left in there. I don't notice any adverse vibration or anything like that so it never occured to me that the sprocket was a consumable like the chain.
    Any advice on how to replace these? Special tools etc? I found one youtube video that shows the process, looks pretty straight forward, but he was using a piece of rope in the cylinder to keep the motor from turning while cranking the clutch off. Is there a better way than stuff a foreign object into the motor??
