Another little ash tree
Discussion in 'The Wood Pile' started by Shanks, Aug 22, 2015.
  1. Shanks
    Shanks
    pa
    Finally got around to cutting the dead ash in the next door neighbor's back yard. I had the missus drive the tractor while I cut and loaded. I will try to finish the cleanup Sunday. 2015-08-22 22.08.49-1.jpg 20150822_174759-1.jpg
  2. cnice_37
    cnice_37
    Yowza, 36" bar? Is that the fabled 288xp?
    WVhunter and Shawn Curry like this.
  3. Shanks
    Shanks
    pa
    36 on a ported 288 with an 8 pin. It screams.
  4. HDRock
    Little big un :saw: nice work man :thumbs:
    Time for :cheers:
    WVhunter, Shawn Curry and Chvymn99 like this.
  5. Chvymn99
    If that's little, mmmmm what's big then? :emb: ... Nice tractor!:yes: Good job.:D
  6. WVhunter
    WVhunter
    Mountains of WV
    Good job, great looking saw!!!!
    Shawn Curry likes this.
  7. Frank and Beans
    Frank and Beans
    Love that dead, barkless ash. That's some good stuff, right there.
  8. Backwoods Savage
    Sweet. Any idea of the weight of that log in the bucket? I ask because I'm curious of how much one can lift with that size tractor.
    WVhunter likes this.
  9. Shanks
    Shanks
    pa
    about 500 lbs. the bucket will lift 780 lbs but you need ballast on the back. They say breakout force is 1100 lbs but you cant really use it cause the back tires com e right up off the ground if its too heavy. I made a weight out of a 750lb per foot I beam cut to 6 inches then fit up the three point hitch attachment points. I picked the splitter up when it was unloaded off the truck with a long chain as a basket. box pallet and all. the splitter itself weighs 680lbs plus all the wood in the packing. It had no problem with that. It is the perfect size for where im at now. a 60in mower deck, 50in tiller, 48in brush hog.
    WVhunter and Backwoods Savage like this.
  10. Backwoods Savage
    Thanks Shanks. What model number is that tractor or what would be the comparable number for this year's model?
  11. Shanks
    Shanks
    pa
    BX2370
  12. The Wood Wolverine
    What part of PA are ya?
  13. Kevin in Ohio
    Kevin in Ohio
    Here's it's Dad.
  14. Scotty Overkill
    Did a tiny ash last weekend myself.....40" diameter at the base, right between a big shed and a power line.....
  15. unclefess
    unclefess Guest
    nicely done ,fairly tight area
    Drvn4wood likes this.
  16. Shanks
    Shanks
    pa
    Beaver falls. North of pittsburgh
    The Wood Wolverine and Drvn4wood like this.
