Air ratchet repair
Discussion in 'The DIY Room' started by Butcher, Feb 8, 2015.
  1. Butcher
    Butcher
    I have an older A.R. that has hardly seen any use. I went to use it the other day and it is just blowing air out the exhaust and not turning. I'm thinking that an O-ring has dried or the vanes in the air motor are stuck from just sitting for several years. Any of you ever had any luck fixing 1 of these things? I looked up parts and diagrams on line and man, there is a lot going on inside of 1 of these things.
    wildwest likes this.
  2. prell 73
    prell 73
    ia
    Spin it by hand to get it to turn than oil the pizz out of it should work that's what I do when all my air tools do that .
    Sam and wildwest like this.
  3. badbob
    badbob
    x2 and after getting oil inside tap on wood to loosen vanes.If too rusty might not be worth taking apart,also would depend on brand.
  4. Butcher
    Butcher
    Thanks. I pulled the side plug and put oil directly into the motor the other day and will see if that helped. If not I might try some Sea Foam or P.B. Blaster. It's not a high dollar tool and obviously not 1 that I use often but still hate to give up on it. (Craftsman bought in 1991)
    wildwest and prell 73 like this.
  5. badbob
    badbob
    Use the PB. Seafoam should be outlawed.
  6. eatonpcat
    Why outlaw Seafoam??
    prell 73 likes this.
  7. badbob
    badbob
    Being a mechanic I have seen lots of damage done over the years,as it is a strong cleaner but leaves no residue protection.I know people use it once a month in their vehicles,swear by it and how great it makes them run.If you need a chemical additive once a month you are masking other problems.It has good uses,just overused,in my opinion.
  8. eatonpcat
    Thanks...I use it in the spring to help clean the carbs in my mowers, seems to work, but I have know idea what I am doing
  9. prell 73
    prell 73
    ia
    I like to use marvel oil to that's good stuff.
  10. badbob
    badbob
    Sounds like you are using it for what it is made for.I prefer BG products,just cant always find.
    eatonpcat and prell 73 like this.
  11. JustWood
    JustWood Guest
    Might be just cold . If so get it inside and PB blaster it right through the air hose intake. Squeeze trigger when you do it so oil gets internal.
    Id prolly set it near wood stove just to evaporate the moisture out of it.
    I got them all the way up to 1" drive and they all hate cold.
    Sam likes this.
