Advise on how to drill through clutch cover
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Jul 31, 2014.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    My 362C-M came home today and I am about to put the dual spike kit on.
    But... I forgot the 362 doesn't have a pre drilled Clutch cover. So what would your advise be? I am gonna drill from the inside, but should I put tape over where the bit will come through? What kind? I don't want to chip the paint ;)
    lukem, Chvymn99 and HoneyFuzz like this.
  2. DexterDay
    Northeast Oh
    This shows that the new kit is the same size, but adds a larger bottom tooth and a chain catch.. Also eliminates the cheap stamped stock spike/dog
  3. lukem
    I'm glad you posted. I was wondering the same thing for mine that I'll hopefully install this weekend.
    :popcorn:
    DexterDay and clemsonfor like this.
  4. pigpen60
    pigpen60
    foley, mo
    well if I read this right then I would carefully mark where you want your holes on the backside and drill with an undersize bit from again the backside and then drill to size from the outside(painted) side. debur with countersink or what-have-you. hope this helps.
    rookie1, concretegrazer and DexterDay like this.
  5. DexterDay
    Northeast Oh
    That would have probably worked great. But I was getting impatient and couldn't wait anymore. . :)
    There is a hole inside the cover. Where they normally would be, and the instructions show to use a 7/32 bit and just drill from the inside, to the outside. But I was worried about chipping.
    I ended up using the next size down (3/16) bit, because the 7/32 seemed like it was gonna be sloppy. I put masking tape over where the bit was gonna exit. Ran the drill at a fast speed, but light pressure.
    Worked great..
    Lukem, your gonna be shocked at the sheer amount of chips that are created when you drill that cover out. :)
  6. pigpen60
    pigpen60
    foley, mo
    im glad it worked out! I hate working on a toy, especially one that hasn't been scratched yet!
    DexterDay and Chvymn99 like this.
  7. pigpen60
    pigpen60
    foley, mo
    whats that roller for on the bottom?
    DexterDay likes this.
  8. Jon1270
    Jon1270
    Pittsburgh, PA
    I see I'm too late, but this is what I was going to post:
    I'm going to differ with this. If you drill a small hole first then it will have to be much smaller than the final hole, or else it will be liable to make the larger drill act like a screw instead of a drill, biting in too deeply and trying to thread itself through the thin clutch cover material. This can cause all sorts of havoc, from diverting the drill away from where you wanted it, to chipping out a rough hole or even cracking the cover material, depending on how powerful the drill is and how fast it's turning.
    I would probably just centerpunch the hole locations on the outside and then immediately use the correct drill size in a handheld VS drill, lubed with a nice puddle of oil, taking it very slow and easy as the bit began to emerge on the inside of the cover. I'd finish up with a couple of turns of a countersink on each side as pigpen suggested.
  9. lukem
    Looks great. Was the 3/16" a good fit or should I go with 7/32"? Waiting somewhat patiently on the full report.
  10. pigpen60
    pigpen60
    foley, mo
    when I do a pilot hole I usually drill it with a bit slightly larger than the web of the final size bit. but like I say, its not how you get there its the finished product that matters.
  11. DexterDay
    Northeast Oh
    3/16" worked, but was a little tight. So once through, I just spun the drill at a high speed and kinda took some off the sides (not wobbling. But rather pushing against the sides, all the way around).
    But it looks great and I just came in from running it. I only cut about 7 cookies, Dayuum!! This thing Hauls the mail!! No doubt my favorite and I don't regret selling the 036 one bit. I honestly can't believe where it's all coming from. And that added muffler port makes it sound awesome. I had a pretty big hole in the stock outlet already, but this saw obviously benefits from a lot of exhaust outlet! It's a screamer. No doubt would take a stock 70 cc saw. No doubt..
    cnice_37, clemsonfor and lukem like this.
  12. DexterDay
    Northeast Oh
    But the 7/32" would probably be a one and done deal.
    This has to be the biggest gain in performance on a stock saw that I have run. It is UNREAL how strong it is..
    clemsonfor likes this.
  13. Pallet Pete
    Pallet Pete Moderator
    Ovid
    That saw is way to clean! Go get it dirty….. :dex::dex::saw::saw:
  14. HittinSteel
    HittinSteel
    Wooster, Ohio
    Man that saw looks bad to the bone with the dogs, roller and sugi......... Im gonna have to take another weekend drive northwest soon :)
    Chvymn99, clemsonfor and DexterDay like this.
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Glad you got the dog mounted. IMHO, Jon1270 provided the best method.
  16. Carbine
    Carbine
    Nice looking saw friend :)
  17. lukem
    I would say I'd like to run it....but I fear it would cost me $300...plus shipping.
  18. DexterDay
    Northeast Oh
    Out of every saw I have had stock and ported.. This saw takes the cake.
    It would be money well spent.
    Anyone who is close enough to come run it? Should come run it. It is an amazing feat for a 362. I HATED the 361 and OE 362. But the new 362C-M is a Monster..
    And that is a pretty chitty chain (Forester). A good chain and this thing will be like a light sabre!! :thumbs:
    Chvymn99 likes this.
  19. DexterDay
    Northeast Oh
    Come on bro.. I have 4 days off Labor day weekend. One day should be for running saws!
    Chvymn99 and clemsonfor like this.
  20. DexterDay
    Northeast Oh
    I forgot to answer your question earlier.
    It's a chain catch. If your saw throws a chain? It won't bunch up under the clutch cover and possibly crack it.
