Advice needed for Woodstove cooking
Discussion in 'Modern EPA Stoves and Fireplaces' started by JA600L, Nov 29, 2015.
  1. JA600L
    JA600L
    Lancaster, Pa
    Hi guys, I'm trying to get into utilizing my Woodstove for cooking. I would like to make breakfast foods, saute vegetables, as well as some breads, muffins, etc..
    I am using a hybrid stove so my main question is have others had the most success cooking during a cat burn or with secondaries?
    I would also be interested in seeing what all pots, pans, and skillets you use.
    How can I get the most out of cooking on the Woodstove? Thanks.
  2. Grizzly Adam
    Grizzly Adam Guest
    We cook a lot on our Drolet, we use cast iron mainly. An infared thermometer and a trivet are both really helpful-- if the top is too hot, put it on the trivet!
  3. Well Seasoned
    We cook like Grizzly, but also inside the stove using CI. If there is a small coal bed, ill add a small piece of hickory, a steak or chicken and cook it inside. The hickory adds a great smoky flavor.
    FatBoy85, Brad M and Backwoods Savage like this.
  4. JA600L
    JA600L
    Lancaster, Pa
    I have cooked meats inside the stove with great success. I'm looking for more information on stove top cooking. Thanks.
  5. Grizzly Adam
    Grizzly Adam Guest
    To get the most out of cooking with the woodstove simply cook only with the woodstove. Works for us!
  6. yooperdave
    As Grizzly already stated, use trivets. I started out not using them and then as soon as the vessel (dutch over, fry pan, pot, etc.) got too hot, I tried to balance it half on and half off the stove. Don't waste your time trying this! Use a trivet!
    Allow a bit longer for cooking until you are over the learning curve.
    Typically, it seems like you can't go wrong with cast iron (CI).
    As we speak, I'm trying to perc some coffee on my stove top with a glass percolator.
  7. yooperdave
    Coffee is done and man is it ever hot!
  8. HarvestMan
    HarvestMan
    Southeastern Michigan
    Please share some pictures of what you end up cooking. I love the idea of doing this, but I don't trust myself! :flipeggs:
  9. JA600L
    JA600L
    Lancaster, Pa
    I made some turkey bbq, cornbread, and cinnamon bread. All turned out decent. I burned the cinnamon bread a bit, but I warmed the stove up too quick on that one.
  10. Well Seasoned
    Awesome!:drool: Food cooked on or in a woodstove tastes better then anything else!:thumbs:
    Brad38 likes this.
  11. chucker
    chucker
    New York
    i see you have the IS stove. the factory says the center front burner is hottest, followed by the left and right front positions, followed by the left and right on the rear deck. that's 5 positions of varying heat output to play with. i believe the info is on the site.
  12. Backwoods Savage
    In the picture below my wife was making either applesauce or applebutter. She uses the same pots for making bean soup and many other things. We also have some cast iron.
    Cooking on a wood stove is not that difficult. Just try a few things and you'll see. Do not fear doing this as it is a very good thing to have some experience with it because many of us have found out that sooner or later you may be without power and eating cooked food is still a very good experience.
    In addition to cooking, you can also put a large pan of some sort and warm water. You can use this for bath, washing hands, adding to the laundry load, or many other things. Use your imagination and just do it!
    BrianK, MightyWhitey, JA600L and 2 others like this.
  13. HarvestMan
    HarvestMan
    Those of you who cook on your stoves: have you ever had a pot boil over or spilled something you were cooking onto the hot cook top?
  14. JA600L
    JA600L
    Lancaster, Pa
    Thanks for the ideas Dennis! I definitely have the itch now. I really like how my first round turned out. Everything cooked pretty even. Better then I expected.
  15. Grizzly Adam
    Grizzly Adam Guest
    Yep, wipe it up the best your can and it will evaporate in a hurry. Be extra careful with frying oils, but if you do spill them try to wipe up as much as you can and it will make the top of your stove nice and black like a cast iron pan. The smoke is no fun, though.
  16. MightyWhitey
    MightyWhitey
    Unless your stove has "dedicated" spots for pots and pans; the best way to control the heat on our wood stoves is to use a "trivet".
  17. bert the turtle
    bert the turtle
    If I'm worried about boil over I either use a cookie sheet or some aluminum foil under the pot. Also, use a deep pot if possible. Boiling is forgiving- the temperature of boiling water is constant at any particular altitude.
    I use my regular all-clad pans or enameled cast iron. I use a rack out of my oven as a trivet if I need to run at lower heat. Braising is also forgiving- not quite as forgiving as boiling, but easy enough.
    If you are trying to brown something, fry it, etc., it is not as forgiving as above, but you need to attend to that kind of cooking anyway. The nice thing about a wood stove is the high temperatures and high mass tend to produce excellent searing results. If things get too hot, lift the pan off the stove for a bit and coast on the the retained heat in the pan.
    I'm using a Pacific Energy Fusion. (non-cat type stove) More than anything, you just need to start cooking on your stove. You will figure it out soon enough. Don't be afraid to experiment and do remember that mistakes are a necessary part of learning.
    burndatwood and Backwoods Savage like this.
  18. Grizzly Adam
    Grizzly Adam Guest
    I recommend NOT using a cookie sheet!!! I did that ONCE and when I removed it stove top under the sheet was glowing red. This is in one of my videos, some members may remember it.
  19. bert the turtle
    bert the turtle
    That is an important safety tip. Don't use the cookie sheet if it does that to your stove!!!
    Griz, what were you making at the time? I can see a shiny sheet reflecting heat back to the stove top and causing it to overheat under some circumstances.
  20. Grizzly Adam
    Grizzly Adam Guest
    I was making a pizza.
