A little bit of Orange goodness
Discussion in 'The Wood Pile' started by JimBear, Aug 29, 2021.
  1. JimBear
    JimBear
    Not truckloads but Gator loads:
    963BEF7E-884C-4B93-903F-B3340A55C14C.jpeg 62B741AB-A597-49FC-AE5B-1377E6ED31C8.jpeg D4A514F5-9F47-4557-9B02-11B741AE3F86.jpeg
  2. buZZsaw BRAD
    JimBear, JPDavis, Cash Larue and 12 others like this.
  3. JimBear
    JimBear
    Yes, just been sitting in the fence line curing for the last 40 or so years.
    Cash Larue, FatBoy85, billb3 and 12 others like this.
  4. Slocum
    Slocum
    North Central Indiana
    That stuff is on my bucket list!
  5. amateur cutter
    That'll make some real heat when it's cold! I've got about a cord and a half that I'm keeping for zero & below.
    JimBear, Cash Larue, FatBoy85 and 9 others like this.
  6. BuckeyeFootball
    BuckeyeFootball
    Im jealous its my #1 bucket list/holygrail wood
    JimBear, Cash Larue, FatBoy85 and 6 others like this.
  7. BuckeyeFootball
    BuckeyeFootball
    Where have you found it in Michigan? Ive only seen 3 Osage trees here my whole life. Im definitely panting some on out property though.
  8. buZZsaw BRAD
    Yup, then id say its ready. None around here that im aware of. Reminds me or the dead/down black locust i find around here. Great stuff!
    JimBear, Cash Larue, FatBoy85 and 4 others like this.
  9. yooperdave
    :smoke:
  10. amateur cutter
    There are some around me. Every now and again one will fall or need removal. They're not plentiful, but they're around. Look in yards for the hedge apples as you travel around. One neighborhood in GR is loaded with them.
  11. Backwoods Savage
    Sweet haul JimBear! Wish I had some like that.
    JimBear, Cash Larue, FatBoy85 and 3 others like this.
  12. Backwoods Savage
    I know of only 2 trees near us.
  13. sirbuildalot
    sirbuildalot
    Mass
    None of that Orange Gold around here.
  14. billb3
    40 year ... must be hard as a rock
    at least the parts that were off the ground.
    JimBear, Chvymn99, Cash Larue and 3 others like this.
  15. JimBear
    JimBear
    They are hard but the dirt & fence staples that are unseen are harder on the chain than the wood. Most line post are 8’ long so 3’ in the ground & 5’ out, corners posts are usually 10’ so 4’-5’ in the ground & 5’-6’ out & exposed to the elements. Semi-chisel is the best option for this type of cutting in my opinion.
    Chvymn99, Cash Larue, Chaz and 4 others like this.
  16. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Years ago I was scrounging around for some firewood behind our shop at work with the boss’s “high private” 266. Getting mostly down cottonwood branches, until I found some old fence posts. Couldn’t hardly cut one of them, and then I couldn’t cut anything.
    When I got back to the shop the old guy said “looks like you found a couple hedge posts, hard ain’t they? Is there anything left of my chain?”
    My neighbor across the street builds fence and saves all the old hedge posts. Last fall I seen him using a chop saw or miter saw ( not sure what the proper name is) and was getting along pretty good with it. He said he has never had any luck cutting them with a chainsaw.
    Curious to see how you get along cutting them to length.
    JimBear, Chvymn99, Cash Larue and 4 others like this.
  17. FatBoy85
    FatBoy85
    Washington State
    Definitely a bucket list wood. Never burned it myself but I hear this is like a stick of "nuclear reactor core" for wood burners.
    Was it something like this? Believe they are called buzzsaws or a bench saw. I'd love to have one of these for a tractor. Makes sawing up limbs so much easier. They have these in a chop saw format too. unnamed (1).jpg
  18. Backwoods Savage
    Never happened to see one rigged like that one.
  19. billb3
    Well, that's a flat belt buzz saw but the belt is really loose like it's all folded up to be moved around. There's some set-up work required there before it could be used. There certainly are a range of flat belt setups.
  20. Cash Larue
    Cash Larue
    Pine, CO
