A good wood day...
Discussion in 'The Wood Pile' started by Tang, Mar 1, 2014.
  1. Tang
    Tang
    North Central Ohio
    ...at least in my humble opinion!
    Took advantage of mid-40 temps today to get some wood related tasks completed. First up was getting locust logs to a local mill I've used previously.
    I had my tree guy drop two 30"+ diameter black locust trees in early January. I was able to set aside four 9' logs to be milled into boards to replace existing raised garden beds that I originally made from pine purchased from the local box store lumber yard. Going on 5 years this year and the pine boards are showing plenty of rot. Figured the locust would be the best route for rot/bug resistance as well as no chemicals to leach into the soil.
    First photo is when I moved them from the yard to my "landing deck"! Second photo is after getting them loaded on the trailer this morning and ready to head to the mill.
  2. Tang
    Tang
    North Central Ohio
    After returning from dropping off the logs at the mill and running a few other errands, I ate lunch and decided that since the trailer was already hooked up, good time to make a wood run. I believe this is ash, but can someone verify?
    My trailer is 16x7 and I cut with my Husky 372xp fitted with 28" bar/chain until the chain needed sharpened. I could of fit a little more on the trailer but I was starting to tire and decided to call it quits.
    All in all - not a bad day to spend a spring-like Saturday!
    Drvn4wood, Oliver1655, Stinny and 8 others like this.
  3. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    I'm by far no expert, but I'm thinking that looks more like maple than ash. Either way, good haul! How do you load the big rounds? Where in Ohio are you?
    Mitch Newton likes this.
  4. Locust Post
    Not positive and cannot tell for sure by your last picture but if that is showing a pink hue I would say yes you have ash.
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    Looks like a nice busy day! How much is it gonna set ya back getting that locust milled? (if ya don't mind me askin) And that does look like a type of ash to me. Not sure exactly though.
  6. Gasifier
    Nice work there Tang. Dem dere is some nice BTUs.
  7. Tang
    Tang
    North Central Ohio
    I was lucky enough that I was able to back the trailer right next to the downed tree. The big rounds I rolled to the back edge of the trailer, laid them against the back edge of the trailer and then grabbed the bottom of the round and pushed them up. Once on the trailer, I flipped them and rolled to where I needed. A lot of work but not too bad.
    I'm outside of the Mansfield area.
  8. Tang
    Tang
    North Central Ohio
    I'll have to get back to you on the price for milling. A lot depends upon how much metal he finds/removes prior to sawing. The boards should be ready for pickup in three weeks or so.
    Backwoods Savage and HoneyFuzz like this.
  9. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Right on, Ive got some family in Gallion
  10. bogydave
    Some serious BTUs there!
    Great set up
    Positive the second load is ash ? Bark seems a bit off , but hard to tell.
    papadave likes this.
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    Tang, I like that you are a well organized and neat wood worker. I like your work pictures. Nice looking wood!
  12. Chvymn99
    Looks likes ash to me on that trailer...that there will should make some nice splits. :axe:
    HoneyFuzz likes this.
  13. Certified106
    Certified106
    In The Hills
    Man that's some seriously nice wood right there! Great job getting it cut up yesterday!
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great pics there ! Looks like a very good day . I see all us Ohio guys got out yesterday !!!!
    40 degrees seemed like 70 !!!
  15. Tang
    Tang
    North Central Ohio
    I'm not positive it is ash but that's what I'm hoping for.
  16. Tang
    Tang
    North Central Ohio
    Thanks Oslo. I've learned a lot over the last 3 years as to what works for me and what doesn't. I'm still struggling to find the best method for stacking and holding my splits as my staging area is not flat and level. Always having to contend with leaning and at least once or twice a year re-stacking a row that falls over.
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    I have the same problem on level land with stacking. If I go over 5 ft high in a row I find the dried out splits sort of adjust in time and force the row to lean one way or the other.
  18. Backwoods Savage
    Here is what we do.
    1. Cut wood in winter and just sort of stack it but never very careful. We just try to get it in some type of a row. After snow melt, we than split it. 3-31-09b.JPG
    Once split, then we lay down a couple of saplings and stack on them.
    This is all that is left of the above pictures. It was all split and stacked in April, 2009. We'll finish this off next year. Also notice that not much sunshine got to this wood. It is fine.
  19. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    With the way the weather is going this year Dennis the snow might be here until May!:(
    Gary
  20. Backwoods Savage
    I wish you no bad luck Gary but hope you are wrong!
    Gary_602z likes this.
