562XP bar oil adjustment screw
Discussion in 'Chainsaws and Power Equipment' started by dennyf, Nov 28, 2015.
  1. dennyf
    dennyf
    Florida
    On my new (2014) 562XP the adjustment screw only turn one direction...counterclockwise. It seems to have a ramp on the screw because as you turn it the screw comes out and then drops down to the next step. As I understand there are only three settings high, med and low. I seem to be getting plenty of oil, but there is no indication of what step you are on. On the saw it has molded into the plastic + counterclockwise and - clockwise, but the screw only turns one way. Does anyone else have a 562XP bar oil screw that work this way?
  2. Sunfish
    Sunfish
    Success Mo
    Mine turns both ways. Three spots, counter clockwise spot is highest oil flow.
  3. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Mine is the same as Sunfish's. And mine is a 2014 as well. Are you using a tank of oil per tank of gas? That seems to be a good ratio.
  4. dennyf
    dennyf
    Florida
    When I'm almost out of fuel, there is still some oil in the tank. I haven't totally run it out of fuel yet, but real close.
  5. Chvymn99
    That's the way its suppose to go... So that you don't run out of oil before fuel... Its easier to figure out when your out of fuel, before oil. Take the nose of the bar a little way away from an exposed surface and rev it up pretty good. See how much its spraying....
