500i Rattling.
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Jun 14, 2025.
  1. buZZsaw BRAD
    Saw starts and idles fine, but when I go full throttle in the cut it "rattles" a bit. Something to do with the AV?
  2. Chud
    Chud
    NC
    I believe I read somewhere about the top cover fastener having issues. You should feel slop if an av spring or cable is broken.
  3. Screwloose
    Screwloose
    Muffler tight?
  4. Rope
    Rope
    Alaska
    Changing lanes on you. Have you upgraded the AV/suspension system? If not West Coast Saw has a kit for $50-60 that upgrades the springs and rubber to 661 suspension. Take most of the mushy out of it. WCS makes the kits some of the Stihls. I have it on my 500 a few buddies tried mine and I put the kit on theirs. Have it on my 461 also.
    Let us know what gremlin you find. PSA don't feed after midnight.
  5. brenndatomu
    Hopefully it's not detonating...
  6. The Wood Wolverine
    Have you pulled the clutch drum and had a look behind it just to see if something there is amiss?
  7. M2theB
    M2theB
    Central Massachusetts
    Take 5 minutes with a T27, screw driver, scrench, hex, etc and give everything a check for tightness. I’d suspect muffler too.
  8. buZZsaw BRAD
    Maybe vibrating would've been a better term to use. The entire saw does this at full throttle. I hear/feel nothing at idle.
    If the saw was dropped, moved awkwardly etc. would this damage the AV?
  9. buzz-saw
    buzz-saw
    Ct.
    Time for some TLC. Nut and bolt check to start
    Pull hood and clutch cover and give it the air-hose special ; You know " Dry clean only"
  10. RCBS
    RCBS
    Over here
    Any warranty left?
  11. WinonaRail
    WinonaRail
    Indiana, US
    My first thought was...Stihl. :p:rofl: :lol:
    In all seriousness, I had the same issue happen last night with my Echo CS590. Runs smooth as silk with a new chain. Under full throttle it has a noticeable vibration. It was 8:00 pm so I put the saw away. I'll tear into it tonight.
  12. buzz-saw
    buzz-saw
    Ct.
    Yup. My first suggestion would also be try a new bar and chain. Worst case, at least another bar and chain off of something else
  13. T.Jeff Veal
    Did you find the problem?
  14. buZZsaw BRAD
    No, haven't had any big logs to troubleshoot it on. I was gonna try a different bar first.
  15. buZZsaw BRAD
    Ran the saw Friday with 25 & 20" bars. Did it with both. Its more of a vibration. Does it at idle too.
  16. brenndatomu
    Loose nut on the trigger...:whistle:
    M2theB, Screwloose, Haftacut and 12 others like this.
  17. Canadian border VT
    ^^^^^ Made me spit coffee :yes::yes::zip:
  18. RCBS
    RCBS
    Over here
    Probably just needs a tank pizz revved through?
    Only legitimate things that come to mind are the clutch assy and bearings. I hope it's neither.
  19. T.Jeff Veal
    Send it to huskihl for Xtra Sausage
    You won't notice any vibration then...
  20. MikeInMa
    We all know Brad is nuts(who around here isnt?) But I don't think he's loose. :dex::rofl: :lol:
