4 " flex chimney liner preferences?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by gmbb, Apr 26, 2022.
  1. gmbb
    gmbb
    northern new england
    Any suggestions on name brand chimney liner for new pellet stove? It will be going in a brick lined , straight chimney 23'. Some are double wall and thicker and others are single wall. Is one better than another for pellet use? I will insulate with a kit.
    Thank you
  2. jtakeman
    The flexible liner itself are pretty much the same, The connections to the stove is where the money is spent. Duravent PelletPro is the most common, But you must seal each joint(as they leak) within the dwelling!! Same goes for selkirk.
    I personally like the Olympia Ventis or Excel IC, But depending on your location. It might be harder to locate.
    imacman likes this.
  3. gmbb
    gmbb
    JT, Thank you, I will look into your suggestions.
    imacman and jtakeman like this.
