346xp NE max rpm
Discussion in 'Chainsaws and Power Equipment' started by jdonna, Mar 17, 2015.
  1. jdonna
    jdonna
    MN
    Finished up a 346xp NE build. Lowered the squish to .017", mild port, muffler mod, zama el-32, tank vent tweak, unlimited coil out of a 2145.
    Pulls 180 PSI with a used piston/ring and cylinder.
    Did a test and tune on this saw, and it was 4 stroking at 14,700 rpm at about 1 turn out. Did some noodling with a 16" .325 oregon lpx and it cuts like mad.
    I know the max rpm is supposed to be 14100-14200 rpms.
    Being that this build is not extreme and similar to what others do for building.. what are you all running for tached rpms on a modded 346xp?
  2. Gunn
    Gunn
    Plover, Wi
    Being that your saw isn't stock and most likely differs from other modded 346's - what works for one may not work for you.
    I've seen some tacked out over 15 still 4 stroking.
    $ooline, mdavlee and SAWMIKAZE like this.
  3. jdonna
    jdonna
    MN
    The saw is quite a hoot, but hitting close to 15k is a bit scary with a used bottom end!
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
    I ran a 346 a week and half ago that was about 15,500 RPM.. It four stroked hard.. Probably the sickest 50 cc saw I ever ran..
    The tune is based on the saw and the conditions.
  5. jdonna
    jdonna
    MN
    I've fixed some stock ones oe and ne in the past but finally acquired one for myself to do a mild build. Freaky would be the word for this saw. I think the 2054, 021 and 2141 are going to be benched for limbing and small work.
    DexterDay likes this.
  6. SAWMIKAZE
    SAWMIKAZE
    PGH
    My 2153 stumpy ported will 4 stroke at 15300 , i run it usually a 14000 - 14300..seems like it runs its healthiest in that neighborhood
  7. jdonna
    jdonna
    MN
    That would be my take, regardless of max RPM, it's all where it puts the most power in the cut.
    $ooline, DexterDay and SAWMIKAZE like this.
  8. Sunfish
    Sunfish
    Success Mo
    I have a couple that will 4 stroke over 15K, but I run them around 14200. A ported 346 is what I use 90% of the time & not just for 'small stuff '...
    PullinMyPoulan, SAWMIKAZE and $ooline like this.
  9. mdavlee
    mdavlee
    16.2k is the highest I ever seen one register and it was right at the edge.
    PullinMyPoulan and jdonna like this.
  10. Cut4fun
    Cut4fun
    OHIO Redneck
    I ran my ported ones fat for work like 13.8K. But for cookie cutting and only 3 cuts watch out. :faint: I seen 084 066 372 rpm's you guys mention for cookie cutting. ;)
    mdavlee likes this.
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Post from 07.
    My ported 066
    The only thing I found with the Poly flywheel is. When you are turning 15k and one of those little brass inserts from the top cover fall in there unnoticed before starting the saw up for some cutting. It makes short order of them fins right quickly.
  12. Cut4fun
    Cut4fun
    OHIO Redneck
    I know my one woods ported 084 liked 14's for cookie cutting and put a long bar 50+ and richen up no problems. Per new owner. ;)
    The 375 liked higher rpm then above 066 for cookie cutting.
    mdavlee likes this.
  13. jdonna
    jdonna
    MN
    Besides if one is showing off for max RPMs, its kinda a catch 22. It's nice to have racing rpms for limbing, but if you want to bury the bar into some wood, I'm much more comfortable with a slightly richer mix.
    I tached it after adjusting in the cut, was slightly for stroking and am running 14,700 four stroking hard out of the cut.
    FYI: the Stihl EDT-8 is slower than slow response wise. I need to get my old echo back that's on loan.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    edt-8 1.5 sec refresh rate to slow for cost. Want the .5 sec refresh ones.
    mdavlee and DexterDay like this.
  15. DexterDay
    Northeast Oh
    X2.. And I only have an EDT-8. It is not a good tach.
  16. Sunfish
    Sunfish
    Success Mo
    Ported 346 OE tuned for cant racing.
