20 to 25 ton log splitters...
Discussion in 'Chainsaws and Power Equipment' started by KaptJaq, May 27, 2015.
  1. KaptJaq
    KaptJaq
    Long Island, NY
    It has been nice working out of home but I have to return to a desk job for a while. With the commute and everything I will not have time to hand split. I am considering getting a 20 to 25 ton log splitter. They seem to be all over the place in quality, features, cycle time, and price. Anybody have suggestions or comments on what to get or what to stay away from?
    Thanx in advance,
    KaptJaq
  2. jetjr
    jetjr
    Pa/Md line
    Bunch of guys have the Dirty Hands Tools splitters and like them. Pallet Pete, jackel440 and I believe North woods are among the ones that have them.
  3. Stinny
    I rented splitters for years before I finally bought one. Got a rental place close enough to consider that? You might see things you like/dislike on those before you buy.
  4. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I do like mine but it isn't without issues... They didn't fill the hydrolic fluid completly or tighten the bolts at all and the beam pin did not have a pin from lowes. The first start was insane it took 30 plus pulls to get it going but that turned out to be a bad carb. It took a few weeks long phone battle to get them to give me fluid a new pin and a discount given how poorly it was installed. Stay away from lowes... It runs great now and starts one pull. Kohler sent the carb very fast and it was easy to install but still it shouldn't have needed that.
    All that said I would buy it again it was worth the trouble and is ( currently ) the best running engine I have owned next to the preditor on my homeade splitter. Nothing has touched it in performance but this comes very very close.
  5. Pallet Pete
    Ovid
    This is a very common model around our area and is a nice splitter as well as easy to move around compared to some. The only complaint I had while using my buddies is the noise it rattles a lot by the way its designed. I wouldn't hesitate to buy one non the less.
    http://t.tractorsupply.com/en/store/huskeereg;-22-ton-log-splitter-carb-compliant
    My opinion this is one of the best on on the home user market it's actually what I wanted however I found a very good sale / deal on mine. I have experience with this splitter and it's very very reliable and powerful as well as designed well. It doesn't rattle like crazy and has a very good motor. Subaru motors are very very nice.
    http://t.homedepot.com/p/Ariens-174-cc-22-Ton-Gas-Log-Splitter-917011/204248703/
    Backwoods Savage and Horkn like this.
  6. KaptJaq
    KaptJaq
    Long Island, NY
    If you like the predator engine would you consider the HF splitter? 20 ton, $700.
    http://www.harborfreight.com/20-ton-log-splitter-61594.html
    KaptJaq
  7. Pallet Pete
    Ovid
    My biggest concern with a hf splitter is the parts. It looks like they did an excellent job with it however the parts could render it useless if they didn't use common parts like the pump. For that reason alone I'd say no. The motors are Honda clones from what I can tell and are very good. That part would be very good quality.
  8. lukem
    The TSC 22 ton is a very good unit.
  9. Canadian border VT
    Kaptn, only comment is too say get one that goes vertical as well as horizontal... seems like most suggested do but thought I would clarify.. other than that tractor supply or Lowe's dirty but with either one from what I read make sure the person putting it together tightened everything...
    and of course pics of your decision!
  10. prell 73
    prell 73
    ia
    I have a 22ton it splits what ever I throw at it .paid $800 for it on sale it's awesome.very good quality.
    Backwoods Savage, Horkn and jetjr like this.
  11. jetjr
    jetjr
    Pa/Md line
    I knew someone had theirs in their avatar. They do look nice, my old homemade rig is holding it's own for now though.
  12. Horkn
    From what I see, the pumps are all a standardized design. So you could bolt one on from a different manufacturer.
    It's nothing that a drill, a welder, and a grinder can't adjust though.
  13. tskar
    tskar
    wisconsin
    I have a 22 ton gravely, which is now only made by ariens. It has been excellent. One pull starts since I got it. It has a Subaru motor on it. On the plus side it's sold by the local dealership that sells husky and Stihl
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    I have a HF splitter and I am happy with it so far. The engine is great. The layout of the splitter is nice. I am not concerned if the pump goes out. It is probably a copy of a name brand pump. Worst case scenario I'll have to buy an adapter and a pump. Most of the other stuff on it could be fixed with a welder. I think it is a well built splitter, not quite as good as a split fire but it is 1/4 the price. The worst thing about the HF splitter is it has some kind of oddball hydraulic fittings.
  15. bogydave
    20 ton is strong enough to split everything for me.
    I like the 20 ton Speeco, (AKA Huskee, Oregon & the dirty hands looks real close too)
    Horkn likes this.
  16. KaptJaq
    KaptJaq
    Long Island, NY
    This is a slightly long term project. I am pretty much finished with my spring scrounging & splitting. I am going to watch Craig's list and store sales for the next month or so to see what comes up. Hopefully before mid-August I will have something for the fall work. I am leaning towards the dirty hands right now but that may change...
    Thanx for the advice,
    KaptJaq
  17. lukem
    I wouldn't hold your breath as CL splitters seem to go for just as much as brand new ones.
  18. bassJAM
    bassJAM
    Cincinnati, OH
    I went with the DHT 22 ton, but that one along with the Ariens and Huskee are all about the same quality and similar in price. The Huskee and DHT are laid out about the same, while the Ariens is a little lighter with a smaller footprint and better operator ergonomics and probably about the best engine you could put on a splitter. I'm not sure that the overall build of the various parts of the Ariens is as strong as the DHT or Huskee, but it seems like their customer service has fixed any issues for people that own them.
  19. lknchoppers
    lknchoppers
    Mooresville, North Carolina
    Take your time on craigslist and you will find something better than you can buy in the box stores. There are some home made splitters that are much better than you can buy. Look for one with a Honda GX motor and bring some knarley wood with you when you demo it.
  20. My IS heats my home
    My IS heats my home
    Albany, NH
    A couple of us here have the 22 ton ariens (gravely) splitter. It's lightweight compared to the full beam models and I've had it for 2 years now and have put close to 10 cords through it. Only one gnarly yolk piece would not go through. It's got a Subaru engine that starts on one pull most times. When it's cooler it needs more choke and maybe 2 pulls.
