2 stroke oil
Discussion in 'Chainsaws and Power Equipment' started by Richcode, Mar 15, 2022.
  1. Richcode
    Richcode
    Oceanside NY.
    has anyone used Castor oil in there saws i use Blandzall in my McCulloch go Kart
    and my old Stihl saw was fowling the spark plug a lot and i tried in the saw it seamed to
    not fowl the plug as much, a gallon is around $60 but you only 3 or 4 ounces to a gallon
    of gas l love the smell of when cutting logs, now if i buy a new spark plug it will not fowl
    up like the one that's been it the saw for 8 years
    T.Jeff Veal, Horkn and Camber like this.
  2. Mag Craft
    Mag Craft
    South East Wyoming
    If it is not 100% synthetic, I do not run it.
  3. Chris F
    Chris F
    Micksburg, Ontario
    Same here. Never had a plug fouling problem with synthetic oil. Had my Poulin Pro 4000 for 25 years with the original plug and my oldest running saw now is twelve years old with the original plug and no starting or running problems.
  4. Camber
    Camber
    Montana
    Never have. I didn't start using synthetic until about twenty years ago or so. Now I buy lucas semi synthetic by the four gallon case. It was around 120 bucks for the four gallons last fall.
    tamarack, T.Jeff Veal and Horkn like this.
  5. Horkn
    Use the amsoil sabre if you like the smell of castor/ race oil. Then you get the great smell and the 100% synthetic.
    When I'm out of sabre, I run the Stihl or other oil, and it doesn't smell great like the sabre.
  6. Eggshooterist
    Eggshooterist
    Erff
    Bean oil in ope is a sure fire way to gum it up and stick a ring. On the plus side is it will usually protect the cylinder enough to not sustain damage from said stuck ring. Ive seen it more than once. I've done it to see the results.
    Barcroftb, DREAM, T.Jeff Veal and 2 others like this.
  7. Richcode
    Richcode
    Oceanside NY.
    in the vintage Karting group they they swear by Blendzall and they are Mac 90cc saw engines or the engine that they made for the go Karts back in the day
    is there a difference between racing a Kart and cutting logs i see very little carbon build up in the Macs or west bent engines P1020227.JPG
    tamarack and T.Jeff Veal like this.
  8. The Wood Wolverine
    I have because the smell transported me back to my youth. Sure did make a mess! Now it's just an occasional thing.
  9. Richcode
    Richcode
    Oceanside NY.
    OK i just tried it so cause i had already mixed so whats the best oil to use ?
  10. The Wood Wolverine
    No such thing, but you'll get a bunch of opinions for sure...
  11. Horkn
    And some smell really really good!
  12. Eggshooterist
    Eggshooterist
    Erff
    I'll make my exit now. Lol
    Lehman, DREAM, T.Jeff Veal and 4 others like this.
  13. Eggshooterist
    Eggshooterist
    Erff
    There you go. I don't have the pictures of mine anymore. I ran an 800 watt 2 stroke generator for one full gallon of 50:1 Klotz Benol mix. Under a 600 watt load. Took a few hours and the ring was completely glued in and it was the nastiest mess id seen in a 2 stroke.
  14. JimBear
    JimBear
  15. The Wood Wolverine
    Tell me about it!
  16. Mag Craft
    Mag Craft
    South East Wyoming
    100% Synthetic 2 stroke oil. Pick your brand.
    tamarack, Horkn, blacktail and 2 others like this.
  17. buzz-saw
    buzz-saw
    Ct.
    Tons of answers and opinions out there.
    No matter what you pick keep in mind that oil technology has come a long way over the years.
    Saws used to run at 16:1 , now 50:1. 8oz of oil down to whatever it is 2.6 oz per gallon. Some oils even go to 100:1.
    Pick your poison and go with it.
    Some like Budweiser and some Schlitz , maybe it is chocolate ice cream and vanilla for others , perhaps a Ford or Chevy?
    To each their own.
  18. Andyshine77
    Andyshine77
    Cincinnati, OH
    I would not use castor oil in OPE, it gums things up fast. Use a good synthetic. The only oils I flat out won't run are castor, and Lucas two cycle oil. If you absolutely must run a castor, Maxima 927 is the cleanest burning.
    Castor does smell good in small quantities, but it will make you sick if you breathe in too much.
    Mag Craft, tamarack, Lehman and 2 others like this.
  19. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Yep, Amsoil Sabre. Use it all my two stroke motors.
    MasterMech, Horkn, ammoaddict and 2 others like this.
  20. Lehman
    Lehman
    Minnesota
    Seems about any mineral or synthetic ope oil is fine at 40-50:1, no castor oils and no Lucas 2-cycle. First one is dirty and gummy the second one makes the insides look dry like they aren’t getting hardly any oil at all. Every other one seems to leave a decent amount of oil in the bottom end at 42:1. I use 42:1 because it’s easy to mix a 2.5 gallon mix bottle with 2 gallons of gas.
