2 Piece Hatchet head? Cast Iron?
Discussion in 'Axes, Mauls, and Hand Saws' started by TripleF, Nov 9, 2016.
  1. TripleF
    TripleF
    West Central FL Coast
    Picked this little rascal up at an estate sale last week.....
    It appears the head is 2 pieces placed together....
    It also looks like cast iron...
    Any help with identifying this would be much appreciated.
    Dancan, Bluelou, Thor and 2 others like this.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I'll take a guess that it may be either a steel closed die head with the eye punched out. Or it could be a cast steel.
    Cast iron was not used much due to the brittleness. I don't think a cast iron axe would keep an edge unless a hardened steel bit was fitted in the business end.
    A casting sprue circle on the head could put it towards cast iron. The second picture shows a rough texture like a cast iron pan.
    It is a real nice looking piece. It looks like it was hardly used. No mushrooming on the end. I'll lean towards steel though. A spark test could be done on it, but I think it is too nice to wear off some metal for that.
    I do have limited knowledge of metal, just enough to be slightly dangerous.
    Bluelou, TripleF, Thor and 1 other person like this.
  3. TripleF
    TripleF
    Thanks for the insights Jon!!
    I did pick up another hatchet head by C. Hammond Phla that was stamped "CAST STEEL" so maybe this is, as you suspect.
    Spark test? What is that?
    I know nothing about steels, only carbon and stainless.....:picard:
    Bluelou, Bert and fishingpol like this.
  4. fishingpol
    fishingpol
    Taking the piece of metal and touching it to a grinding wheel. It should spark in a particular pattern if it is a ferrous metal. The pattern should indicate what you have.
    eatonpcat, CTYank, Bluelou and 3 others like this.
  5. billb3
    I would guess cast steel too.
    Someone that welds or works with steel could probably tap it with a hammer and tell you if it is iron or steel by the thunk.
    Kinda like green/seasoned wood.
    The rough surface may be easier to mold.
    I've seen cast aluminum pieces that were like two bowls put together to make a housing and the outside was smooth but the inside was rough/pebbled like that.
