16/17 wood may get us thru 17/18
Discussion in 'The Wood Pile' started by bogydave, Aug 19, 2017.
  1. bogydave
    Fresh dusting of snow in the mtns
    Time to start filling the basement with 3+ year old birch
    Guessing about 4-1/2 cords left from the 16/17 woodshed section
    Mild winters & cat stove has reduced consumption
  2. Dsltech
    Dsltech
    Rensselear ny
    Love your firewood chute into the basement
    Eric VW, Sean, HDRock and 8 others like this.
  3. TurboDiesel
    :dex:
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
    nice chute! Can I see some pictures of it in the basement?
  5. TurboDiesel
    Check out the link in Dave's signature :yes:
  6. Warner
    Warner
    +1 on the chute! I wish I could rig something up like that but it would require cutting a hole in the foundation. A walkout basement was high on the (my) priority list when looking for our current home. We found one with everything we wanted but a bulked. Not looking forward to the 1,000s of trips up and down coming up.
  7. Locust Post
    Hopefully this doesn't mean we won't get pictures of your journeys to the cutting area this year.
  8. MikeInMa
    No bulkhead? Then you have a walk-in basement? I use one similar to this at times. Works fine.
  9. Backwoods Savage
    That's good to hear Dave. That is, snow in the mountains and the firewood lasting longer. Hearing about snow dusting in the mountains makes us think cooler weather is just around the corner now.
  10. mikeward
    mikeward
    Long Island, New York
    bogydave great system you have there. Always love looking at your photos!
    Warner we have an covered outside cement staircase to basement not bilco
    when I need to bring something heavy down it, I put a couple of 2x8s the full length of the stairs, and slidestuff down or up.
    Worked for my old oil burner up and the new one down. Old oil tank up and new one down also
    For wood you could mount a rubbermade tote on top of a movers dolly and slide it down and roll to storage and unload.
    Make the wood act as rails to guide dolly down. Might have to double up 2x8s so wheels don't hit step.
  11. Greg
    Greg
    Love the firewood chute
  12. billb3
    sounds like the shed needs an addition
    my sister has a 8 inch insulated chimney for her stove but it doesn't look quite so huge painted flat black and mostly hidden in a chase.
  13. justdraftn
    justdraftn
    On the road
    Nice wood chute.
    When I lived in Ak. I built a daylight basement.
    There was not room to store wood in the basement, so I build a wood door next the stove.
    Just stacked the wood by the door. Didn't have to go out at night for wood.
    The wood shed was right outside that door. Actually the best wood setup
    I have ever had.
    That snow on the mountains....we called it termination dust.
    Has the fireweed topped out yet?
  14. HDRock
    Get yourself a metal slide, from a kid's old swing set, let them splits side right down,, move it out of the way when you're not using it, it would be a lot lighter than anything made from wood.
  15. bogydave
    Fireweed still blooming
    "Termination dust" a week or 2 early this year
    has been a wet summer
    Ha ha
    Great minds think alike
    Using a piece of a plastic slide from an old swing set:yes:
  16. brenndatomu
    Which isn't really that hard to do...even if you had to hire it done, I don't think it would cost much to have a mason mortar a wood chute in there...would be money/time well spent compared to carrying wood in forevermore.
  17. HDRock
    Plastic ,even lighter weight :yes:
  18. HDRock
    I like how you load that wagon Dave :thumbs::dex:
    My IS heats my home and Chvymn99 like this.
  19. Warner
    Warner
    I have tried that, only so many slide down till it backs up, then when you are at the bottom stacking it all slides down on you.
  20. Warner
    Warner
    Possibly, I'm hoping to move to a mor efficent stove so that will cut back on the trips
    HDRock likes this.
