14.5 hours of usable heat from the 30
Discussion in 'Modern EPA Stoves and Fireplaces' started by BrowningBAR, Jan 31, 2014.
  1. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    That's the difference between a high of 37 vs. a high of 17. Stove, on reload, was at 220 degrees.
  2. BrianK
    BrianK
    West central PA
  3. Certified106
    Certified106
    In The Hills
    I know what you mean! We went 15 hours on a 3/4 load in the T6 last night and the stove still close to 300 degrees! I am so thankful for the break in the cold!
  4. jeff_t
    jeff_t
    SE MI
    I loaded up about 10 last night. It was burning pretty hard, and sometime overnight the wind died down. Woke up to a 79° house :thumbs::thumbs: Cranked the air down and shut the blowers off. Gonna load it again here in a few minutes.
    Was a nice day to be outside, for a change.
    Mitch Newton and Certified106 like this.
  5. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    No kidding. I was getting tired of the 20+ degrees BELOW seasonal temps.
    I let the other two stoves burn down, cleaned out the ash and the glass. Still running three stoves, but that's just to keep some even heat going on. After tonight, it will be two stoves for the next few days. Both of which will be run much easier with extended burn times.
  6. sherwood
    sherwood
    After the bitter cold we have had, this break with the temp hitting 32 feels like Spring/shoulder season. Sooo easy to keep the house warm with just a few 2 to 3 inch branches. Nice even temp throughout the house. That's the difference between a 35 -40 degree differential between inside and outdoors, and the 100 degree differential we were dealing with. We had two days the past few weeks with lows below -30, lots with lows below -25. And a lot of wind with those cold temps.
  7. jrcurto
    jrcurto
    SW Connecticut
    I didn't check the outside temp after dinner and loaded the stove as usual these days. It got real warm fast as its still in the 30's now. Almost surreal to see that after the past month. Its hot in here now!
    Mitch Newton and Chvymn99 like this.
  8. chris
    chris
    SE WI
    We are having an on again off again heat wave sometimes almost approaches 20 degs F during the day, neg ative # for Wed. night wind chill # around -30
  9. Huntindog1
    Huntindog1
    South Central Indiana
    Browning Bar,
    What kind of wood load did you have for the 14.5 hour burn? Large Splits or medium or a mix and what kind of wood.
  10. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    This was four days ago. I can barely remember what I had for dinner last night. But, right now I am working through some large splits. So, this load should have been about three large splits plus some space filler splits.
    Chvymn99 likes this.
