1129 rebuild
Discussion in 'Chainsaws and Power Equipment' started by big t double, Sep 13, 2014.
  1. big t double
    big t double
    Here's an 1129 saw I will be rebuilding to sell...but first a little trivia...who can tell by looking at this picture what model it it...winner gets an atta boy!!! Or girl.
    Jon1270 and Chvymn99 like this.
  2. MasterMech
    My guess? 020T....
    Jon1270, big t double and basod like this.
  3. basod
    basod
    Mount Cheaha AL
    a ms200T/020 carb in the pic is a giveaway:whistle:
    the GOAT likes this.
  4. big t double
    big t double
    Winner winner chicken dinner. Atta boy!!!
    That's right but the 1129 series covers either of those. More specifically it's an 020t. I put c1q-s32's on 200t's too. No accelerator pump. But the way to tell it's an 020 and not a 200 is when stihl changed to the 200 they changed the cylinder to have quad open transfer ports. That also needed the case to have larger openings to accommodate the larger transfer openings.
    MasterMech and basod like this.
  5. big t double
    big t double
    Here's a 200 cylinder for reference
  6. big t double
    big t double
    And I guess I should've worded that different...here's the 020t that i just got done rebuilding. Got the saw from an old guy...he just plum wore it out. No machine marks left at all on the piston. Still some cross hatch in the cylinder so I reused that. The carb that was on it was the walbro without the high speed adjustment so that got swapped out to the s32. Here it is all layed out and ready to assemble
    Cool..for some reason these are getting posted upside down hahaha this should be fun. (Fixed -- MM)
    New piston gasket and carb
    These piston clip tools are pretty nice...the magnet on this one is broke but it still works with some persuasion
    Here's the clip jammed down in the other piece
    Line it up with the pin...
    Then push the clip home with the other end of the magnetic piece
    basod, cnice_37 and SquareFile like this.
  7. NewToStihl
    NewToStihl
    Central Indiana
    I've never seen one of those - is it a Stihl tool?
  8. big t double
    big t double
    Clamping the rings to install the jug..
    Jug installed...
    Here's the updated tank vent kit for the older tanks
    The brass driver fits around barb fitting and you drive it in...I used a deadblow.
    New vent, fuel line and filter
    Tank installed...starting to take shape
    Installing the handle..pulling the intake thru with starter rope
    Flange installed ready for vac/pressure test
    basod and concretegrazer like this.
  9. big t double
    big t double
    Yessir it is
  10. big t double
    big t double
    Vac/pressure test pass...clutch installed ready for muffler
    020t's didn't have compensating carbs...the new s32 has the snorkel for it to compensate so I got a new connector and cut a hole in the filter base to accommodate it
    Here she is all buttoned up and ready for the auction block with a 14" bar. I know a few tree guys in my area that won't hesitate to buy it so I won't have it very long. Ran it tonight and it ran like any 1129 should...they're little animals
    Thanks for lookin...and if anyone knows how to correct the upside down pictures let me know:thumbs: (On it! -- MM)
    SquareFile and basod like this.
  11. NewToStihl
    NewToStihl
    Central Indiana
    Do you happen to have a part number on that tool?
  12. big t double
    big t double
    Hope you can read upside down...the Australian guys should have no problem reading it:p The 2209 does 9mm wrist pins and the 2210 does...you guessed it...10mm wrist pins. These are the only two I've been lucky enough to acquire. Call me a cheater but I've never lost a Jesus clip using them.
    basod, the GOAT, SquareFile and 3 others like this.
  13. NewToStihl
    NewToStihl
    Central Indiana
    Thanks! I work with an Aussie, so he can translate for me....
  14. Chvymn99
    :popcorn:.... Looks good and nice lay out!
  15. big t double
    big t double
    Thanks!!
    Chvymn99 likes this.
  16. MasterMech
    Are you using a smartphone to take your pics?
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    Very good thread here!! Very detailed and the pics are awesome! !
    $ooline and SquareFile like this.
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    59108902209 & 2210 are like $100 each. Makes the BUX C-Clipper look like a more cost effective choice.
  19. big t double
    big t double
    Yessir i am. Is that why they were upside down? And someone turned them around...so thanks!!!
    Thanks dexterday
    Yea they're pricey that's for sure...not sure on the exact cost but you're probably close. Both of these are broke but still work so I didn't pay for them. Never heard if the c-clipper...got pics?
    SquareFile and DexterDay like this.
  20. DexterDay
    Northeast Oh
    When you take a pic with a smartphone. Make sure the home button is to the right (phone sideways and button/buttons to the right). Any other way and the photos are oriented sideways (if phone is held vertical/home button down) or upside-down (button to the left).
    big t double and Chvymn99 like this.
