11" high raised bed planter from tires
Discussion in 'Everything Else (off topic)' started by bogydave, Dec 8, 2014.
  1. bogydave
    I use a few of these in the garden .
    Black so they absorb solar heat
    Tough, weed eater don't hurt them,
    even the cut out sidewall can be use around shrubs & fill with mulch.
    Cut out the sidewall at the tread
    These are bigger & thicker ones so I had to cut the other bead off to invert. 265 x 70 x16
    WD helps the knife slide when cutting,
    rottiman, wildwest, Daryl and 3 others like this.
  2. jetjr
    jetjr
    Pa/Md line
    I have some that I buried all but about an inch of the inverted tire. Can weed eat up to them and they make good experiment beds. Tried burying some groundhogs and sticks and stuff to compost down in them. Soil seems pretty loose and fertile.
    wildwest likes this.
  3. rottiman
    That's gotta be some tough cuttin', even with the WD................
    papadave and wildwest like this.
  4. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Utility blade works good also.
    Gary
  5. jetjr
    jetjr
    Pa/Md line
    Serrated blade on my leatherman. Only thing I think I've ever used that blade for.
  6. bogydave
    Thin sharp blade , actually pretty fast
    Stiff or locking blade
  7. jetjr
    jetjr
    Pa/Md line
    jigsaw works too may have to try the wd40 trick
  8. wildwest
    Wyoming high plains
    off topic, Bogy, I have a wildlife calender with almost the same pic as your avatar. Everytime I look at it I think BogyDave :rofl: :lol: Doh! I am thoroughly FHC brainwashed! Love your posts :)
    papadave likes this.
  9. bogydave
    Used to do it that way, sharpened a wood blade on the grinder, works ok.
    wildwest and jetjr like this.
  10. DaveGunter
    DaveGunter
    Tires have some pretty toxic chemical in them, getting a lot of press lately about "tire mulch" being used on sports fields, playgrounds and such not being such a good idea. I might worry about the soil for growing vegies being in such close proximity to the tire. Just a thought, I don't know if I buy the toxic argument or not, but I would probably hedge my bet against using them.
  11. bogydave
    Yea
    I've been on those fields , definitely have the rubber tire odor.
    Can see that breathing the rubber dust could be bad.
    Not noticed any odor off tires but you might be right.
    No doubt we live in a synthetic world of paints, plastics & rubber compounds from carpet to clothes to cell phones & fuels.
    Probably should all be walking, & cutting our wood with an axe & steel hand saws
    instead of plastic , rubber & alloy ones powered by mixed chemical fuels . LOL :)
    DaveGunter and papadave like this.
