021 Carb problems
Discussion in 'Chainsaws and Power Equipment' started by swags, Dec 13, 2013.
  1. swags
    swags Moderator
    So about every other time I pull the 021 out to cut I have to adjust the carb. It always bogs down when cutting, I adjust and it's fine for a bit. Then a few weeks later the same thing again. Any ideas?
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Hopefully someone will have an idea to try (other than what we spoke about on the phone).
  3. HittinSteel
    HittinSteel
    Wooster, Ohio
    Have you gone through the carb?
  4. swags
    swags Moderator
    Cleaned the carb and new impulse line earlier this year
    DexterDay likes this.
  5. DexterDay
    Northeast Oh
    Paging MasterMech .... Paging MM :)
    swags likes this.
  6. Boog
    Boog
    Where my spirit is free
    Hard to say what's up Swags, my 024AV was doing a similar thing after I rebuilt it and the carb this spring, constantly had to re-adjust. It finally settled down and runs great now ................... seemed in general that I had it too rich.
    Almost bought you a Christmas gift last night ................. shopping with my girls and saw these sunglasses in a boutique type of shop. They were the mirrored type with the letters SW on the left lens and AG on the right. Probably some "brand name significance" I'm unaware of, but I immediately thought of you!
    swags likes this.
  7. the GOAT
    the GOAT Banned
    Maine
    New carb kit or just cleaned?
  8. swags
    swags Moderator
    cleaned not new, bought the saw after it had sat in a garage for a few years
  9. the GOAT
    the GOAT Banned
    Maine
    Get a new kit/diaphragm
    Hedgerow likes this.
  10. HittinSteel
    HittinSteel
    Wooster, Ohio
    and really clean the needle inlets
  11. basod
    basod
    Mount Cheaha AL
    My brush cutter would do this as well and I took the carb down blowing the needle ports out - haven't had to monkey with it since
  12. MasterMech
    Hmmm, chasing carb adjustments eh? How about day to day? Does it perform the same as it did the day before or does it have to sit for a long period of time to start acting up? I would make sure the engine is mechanically healthy before blaming the carb, of course cleaning the carb with a new kit can't hurt either and it is cheap to do.
    Chasing carb adjustments is usualy something with a degree of variability to it such as dirt in the carb, air leaks, very small fuel line leaks (can be affected by temperature....), or worn rings that don't seal up as well as the saw warms up.
    Standard op here would be a compression check, followed by a pressure/vac test (ensuring the engine is mechanically sound) before turning the sights on the carb.
    swags likes this.
  13. swags
    swags Moderator
    Thanks MM, good excuse to run out to Dex's house now to check the compression.
    clemsonfor, DexterDay and MasterMech like this.
