Tree id black walnut????
Discussion in 'The Wood Pile' started by Woodsnwoods, Sep 1, 2019.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Is this walnut??? F70E3BBF-6EFB-41FE-AFDE-B1AE99CBE834.jpeg DFBCA2AE-0B18-4990-8326-711ED54D9015.jpeg 436155DB-A730-406F-A586-DBA4B142A0D0.jpeg
  2. Ikeholt
    Ikeholt
    indiana
    Maybe Butternut. Leaves look more like hickory. Find some nuts on the ground, that's the best way to figure it out.
  3. clemsonfor
    Not that dam tall!! Least not like them around here. Bark looks wrong. I also say one of the hickory's. If it's black walnut and you can get a twig, you can cut it with a knife and look for the center. But walnut would not come to my mind seeing that at first.
    Trees can be tricky though. As a Forester you see trees every now and then that make you look twice.
    Sent from my moto g(7) using Tapatalk
  4. buZZsaw BRAD
  5. papadave
    And highly valuable.
  6. buZZsaw BRAD
    Why do folks think it's worth a lot of money?
  7. papadave
    Urban mythology, I guess.
  8. Chvymn99
    Not any Black Walnut tree I’ve seen...
  9. Scotty Overkill
    Looks like bitternut hickory to me.....
  10. amateur cutter
    X 2, cut er up. Great firewood.
  11. Scotty Overkill
    Oooh man I luvs me sum hickree!!
  12. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have a ton of bitternut hickory and this one is very different. I may just drop it to find out.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Bitternut is in the first picture, behind the one in question.
  14. Backwoods Savage
    Just one more old wives tales like the pine burning down the house. Perhaps this tale is even wider spread as almost everyone I've run into outside of loggers and mill workers think they have a treasure chest when they have walnut. When I was milling, people would come and ask what they could get out of a good walnut and we'd tell them they could get a great fire. Trouble is almost all would come from a yard or fence row. Beware the hardware.
  15. clemsonfor
    They say it cause there were some veneer logs back in the day that we're good quality that would bring big money. That was an isolated market with limited capacity. But good veneer logs did and would bring good money. This was probably bin the 80-90s. But that one "big" yard tree you have is probably worthless.
  16. JoeinO
    JoeinO
    NEO
    IMG_0266.JPG I know for a sure this is butternut aka white walnut.
    This I got from Ohio DNR forestry: Ohio common trees. Site has great info on trees that grow in this part of the world
  17. clemsonfor
    And on the black walnut you can see the defined pith and the tell take Chambers. That's why I said get a twig and slice it open long ways (like your witteling it to the center) and you can know right away if it's walnut.
  18. mr.finn
    mr.finn
    Mass
    Looking at the bark I want to say elm, but the canopy says different. The leaves look like butternut and after a quick lookup the bark looks like it also. That's a big one!!
    Woodsnwoods likes this.
