  1. imacman
    imacman
    Denver, NC
    :picard:IMO, WAY, WAY too long to not have been cleaned. 6-7 years is all I'd ever wait before having it done. And that is with adding Rid-X every 3 months or so......ESPECIALLY since you have the equipment to dig it up easily.
    IHATEPROPANE, wildwest and ivanhoe like this.
  2. Earl764
    Earl764
    CT
    Yah, every 3-4 years for me and that’s with two adults.
    ‘93? That’s a lot of turds. Did they make it to the leaching field?
  3. bogieb
    That is going just a bit long between cleanings! At my previous house we waited 12 or 14 years before the first cleaning. We actually did it because the Ex had crushed one of the leach field pipes while driving a truck over it and burying the back end while trying to pull out a stump. Figured while he was digging up pipe, he might as well dig to the tank and check out how everything was doing.
    When the guy pulled the cover, it was almost to the top. Guy suggested every 4-5 years (just 2 of us).
  4. ttdberg
    ttdberg Pellet Pig
    CT
    Snowy how come you never got that tank pumped out? Didn’t know you had to? Hope the leach field isn’t buggered! Set a reminder, every five years - done.
  5. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I knew that eventually the tanks fill with sludge.
    We don't use harsh chemicals in the toilets and such.
    Actually 26 years.
    A lot of good living in that tank :rofl: :lol:
    Guys showed up about noon and since we had the top cleared they just popped the big clean out cover off and sucked it out.
    took 30 minutes total...
    $378.00
    Great deal.
    They gave military discount too....10% was $420
    Now I gotta cover the thing back up.... Arrrrrgh
    I may order 5 yards of sand and fill the hole with sand instead of dirt...
    Easier to dig out later.
    Or I may put it a plastic tube with a cover so the clean out bung can be readily removed without digging.
    For the next month or so I am gonna leave the top uncovered.
    That sucker was full to the brim.
    Luckily the drain outlet to the leach field was fine.
    Mostly it was an issue with the inlet drop pipe was clogged at the bottom and the inflow was trying to flow out the top of the inlet T against the tank top.
    Just waaaay too long without getting sucked .....
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    In this state the area over the tank and the leach system must be loomed and grass seeded.
  7. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Our leach lines run through the horse paddocks.
    No spec on the cover over the tank.
    I want to make access in the future easier and not
    require the tractor or SHOVEL
    I figure 2024 or so and we can pump it again.
    I may not be around, but the daughter and son in law will be.
    26 years this time through...
    It will likely do 10 years with no sweat.....
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well the filter for the fridge got changed it took the both of us and this was the first time I was on my knees since I was there due to dehydration.
  9. Earl764
    Earl764
    CT
    The pellets are in the building!
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    That's good its gonna rain
  11. bogieb
    Yeah, I rode in to work on the bike because last night they said the rain would start at 5 or 6 pm today. Well, I left work shortly before 4 and it was lightly raining then. Then I hit some REAL rain about 20 miles from home and the rest of the way to my driveway. Turned on the news and I had been riding thru a yellow & red area on the radar. I was happy I had my leathers and 3/4 helmet on so the hard rain didn't sting at all. But I did have to keep wiping the inside of my face shield to get the fog off. IMy gloves were so wet I could wring them out - but my hands were dry :thumbs:. My pants from the knees down were wet because it crept up from underneath the chaps. But, it is 68* out, so never felt cold.
    At least all the bugs from this morning's ride should be washed off the bike. Probably got replaced by a ton of road grime though.
  12. Pete Zahria
    Pete Zahria
    New Hampster
    Oh yeah... never fails...
    rain is one way to insure that your bike will get detailed asap..
    As for the rain.. I've gotten stuck several times,
    where the paper money in, and, my wallet,
    had to be put on towels to dry out overnight..
    I hate it when that happens...
    :picard:
    Dan
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hey Snowy is it shake, rattle, and rolling out your way?
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hey, the Bear is taking bets on USPS delivery will it make here from South Portland normal devilry is out of Gorham.
  15. imacman
    imacman
    Denver, NC
    20 miles...........I'll say 3 days. :rolleyes:
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Sometime after I empty 7 bladders and tap 23 kidneys, Bear is a bit strange in his internal plumbing.
  17. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Yeah buddy
    We had a buttload of HIGH BASE T storms roll through about 2 am yesterday morning.
    Lottssa flashing and booming but little to no rain with these boomers
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    By shake,rattle, and roll i was thinking of the 6.4 and thousands of aftershocks.
  19. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Well now.
    With the Septic tank all pumped out and working good again life is great.
    The weather was scorching Tuesday and Wed.......with highs anywhere from 98 to 106
    We were up in Portland on Wed and the temp in the cars readout showed 101 to 106 coming home.
    About 94 here at the ranch (1250 feet elev.)
    Yesterday dawned much cooler with a few sprinkles
    Today it's cloudy (Heavy marine layer) and it may not clear off until later this afternoon. yessssssssssssssssssssssss... :yes:
    I am pleased that this summer has seen far less 90 plus F days compared to last year.
    Last summer saw 15 90F or higher days in July
    From June to September we had a total of 30 days of 90 F or above
    So far this summer were are at 9 days of 90 F or above
    July was much cooler...August has been about norma.
    We actually had fires in early July as it was cool....
    I am ready for fall.
    Went out yesterday and replaced a couple boards on the Deck.
    Two boards had the ends rotted off and they were not sitting on the joists.... unsafe totally.
    Ripped those bad boys out and dropped in some new ones.
    I was afraid somebody was gonna step on them and maybe go through.
    These were originals from 1993 when we built the place....can't complain on that long service life.
    I still need to replace about 15 boards.... some are just cracked at the ends, but are still safe.
    Maybe next year....:yes:
  20. bogieb
    Went and picked up my next-to-last ton of pellets that I had on layaway. So here is my stash minus the 1 ton I still have to get.
    65 bags by the washer in the basement
    69 bags in the garage - I broke that bag but saved most of the pellets (top row is only 4 because that pipe jogs down)
    105 bags between the washer and dryer (big pallet so it is 7 bags to each row)
    Adds up to 4.8 tons so far
    Don't bother :vulture: because these are all under lock and key and maybe a bit of :rootintootin: for back up :D
