Stove pipe temp gauge?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Qya1991, Aug 20, 2019.
  1. Qya1991
    Qya1991
    What are your guy's opinion on stove pipe gauges? My stove pipe is double wall from the stove to the ceiling. I've been around and ran multiple wood stoves my whole life. So would it be safe to say I could go off of the looks of the fire and be okay? Any input will be appreciated.
    Sent from my E6910 using Tapatalk
    Backwoods Savage and Chaz like this.
  2. papadave
    I quit using a pipe gauge. I do have a stovetop gauge though, and I also use an IR gun occasionally.
    I just get the fire going, reduce air, and leave it alone for a while.
  3. Qya1991
    Qya1991
    That's where I'm at with it I use my ir gun. What temp do you look for on top of your stove?
    Backwoods Savage, Chaz and papadave like this.
  4. papadave
    I like to try keeping temps under 600, unless it's really cold.
  5. bushpilot
    bushpilot
    Eastern Washington
    I do the opposite, I use the pipe gauge, and ignore the top. But I also use an IR gun ...
    I find the pipe to be a good indicator of where the fire is, and therefore what direction the stove is going, while the top indicates the heat output right now.
  6. Chaz
    Chaz
    Southwestern NY
    Welcome aboard Qya1991
    Since you have double wall pipe, I presume you are looking at a probe style therm.
    Since you're an experienced burner, not sure it's worth the hassle.
    $.02
  7. wildwest
    I echo your thoughts. We were given one as stocking stuffer in the early 90's that hung around for a lot of years but went by the looks and sound of the fire, and for me, the smell of the stove & pipe.
  8. Backwoods Savage
    I've burned wood for over 60 years now and most of that time I never had a flue thermometer. I have one now but could easily do away with it. Keep and eye on the stove and the fire and you should be good. Also with double wall, you will be looking at a probe of a temperature gauge if you go that way.
    brenndatomu, Qya1991 and Chaz like this.
  9. Highbeam
    Highbeam
    I really like the probe meter for my double wall. I can read it from across the room since it faces forward and I am not concerned with stove top temperature since the stove thermostat takes care of that.
    It is very easy to overfire the flue during warmup. That’s the biggest reason to have one.
  10. fox9988
    fox9988
    NW Arkansas 72717
    ^Yes^
    Qya1991 and Backwoods Savage like this.
  11. Locust Post
    Don't see much of a need for them but I have gotten pretty religious about setting a timer on startup so I don't get sidetracked.
  12. Old Nate
    Old Nate
    Western PA
    I’ve been debating whether or not to get one... seems like it’s something I should have esp since I’m relatively new at burning with wood.
    NVhunter likes this.
  13. NVhunter
    NVhunter
    Northern Nevada
    I'm also on the fence with getting one. I have double wall stove pipe so I'll have to drill into it for a gauge on it.... I have a cat probe which I'm wondering if it's a mood point to get a pipe probe too since I have the cat probe....?
  14. fox9988
    fox9988
    NW Arkansas 72717
    I have both. I keep the pipe temp out of the red (which can happen very fast with the cat bypassed and draft set high, flames going right up the chimney), until the cat probe comes up to temp.
  15. NVhunter
    NVhunter
    Northern Nevada
    Good point, maybe I'll install one. Which probe do you have for your flue?
  16. Old Nate
    Old Nate
    Western PA
    I also have a double wall pipe out from the stove. It’s a telescoping double wall... I’m thinking it might be a little bit of a pain but maybe ppl install them all the time i their telescoping double wall??
  17. NVhunter
    NVhunter
    Northern Nevada
    How difficult was it to drill into the telescoping double wall?
    I don't feel like screwing up my stove pipe...
  18. Old Nate
    Old Nate
    Western PA
    No, I’m asking as well. To me, that seems like something I would just rather not mess with.
  19. fox9988
    fox9988
    NW Arkansas 72717
    I kind of misspoke. My connector pipe is single wall, surface thermometer only. Its an Imperial brand, notoriously inaccurate brand but mine is right on with my inferred. My cat probe is a Condar, quality products.
  20. hovlandhomestead
    hovlandhomestead
    MN
    I run a single wall stove pipe straight up to the insulated pipe. I have a magnetic temp gauge on both the main cabin and bunkhouse stoves 18" up the pipe. We educated our children to keep the fire in the "burn zone" as long as possible with a load, and what to watch for before adding more wood.
    I think it is a good tool to help learn to run a stove properly when you are first starting out. They also learn about the temperature variation in the flu with different types of wood, as well as conditioning them to be mindful at all times running a stove when they are up there on their own with their friends.
