Turn me on....
Discussion in 'Modern EPA Stoves and Fireplaces' started by scavenger, Aug 17, 2019.
  1. scavenger
    scavenger
    saybrook township ohio
    This morning I got on the roof and cleaned the chimney. I might have had a gallon of buildup to clean once I got back in the house. Not bad for an October to May burn season. What I need is for someone to turn me on to how to change out my fire bricks from the burn box. There are 3 rails holding the bricks in position that are solidly attached to the metal box although I see 2 spots on each where they appear to hitch on. These rails have to be popped to change the bricks. Do I tap with a hammer? Will they go back on? The last thing I want is a broken stove! See the page I've attached and let me know what to Do! Item 13 and 14... 20190817_104550.jpg
  2. Eric VW
    Hey stranger! :salute:
    Are there firebricks in the bottom/floor of the stove?
  3. scavenger
    scavenger
    Yeah....that may be why the manual says I'll need 14 bricks....hi yourself!
  4. Eric VW
    If the rails are permanently attached, remove the floor bricks and the side bricks will drop down.
    Even if you’re somehow able to remove the rails, they may have suffered some warping from countless fires and could be challenging to reinstall. But perhaps not.
  5. scavenger
    scavenger
    6 bottom bricks....8 side bricks...
    Look at that! Bet if I pried the bottom the rest would follow! BRILLIANT! Guys from Virginia know how to turn you on! Now where is best to buy said bricks?
  6. jo191145
    Masonry supply will have standard sizes. Not sure if that helps though.
    Going off of pure memory which is far from pure a standard firebrick is roughly 4 1/4” x 9 1/2” and 2 3/8” thick.
    Skinny version of that which I’ve never used one is a guesstimate of 1.5” thick.
    Willing to bet it’s a lot cheaper at a masonry supply than ordering from a stove manufacturer. If the size is right.
    Cutting those brick even with a diamond blade is a job.
  7. Eric VW
    Ha!
    Rural King/TSC/Menards.... probably a little spendy. USSC branded- very spendy.
    Measure them up.
    Report back.
    T.Jeff Veal, Chaz, Chvymn99 and 7 others like this.
  8. papadave
    Do that.
  9. jo191145
    On a side note you could order some custom cut soapstone slabs from Woodstock. Much sexier.
  10. wildwest
    Wyoming high plains
    Interesting, I did not know it needed to be changed, woopsie if it does. Only replaced one cracked one, but even that hung in there for several years before a chunk finally chipped off. How often?
    T.Jeff Veal, Chaz, Chvymn99 and 5 others like this.
  11. scavenger
    scavenger
    1.25x4.5x9.5....soapstone? Making some inquiries at present...thanks
  12. scavenger
    scavenger
    4 or 5 of my originals have gouged out from wear and packing it in tight like I do...to over heat things...
    T.Jeff Veal, Chaz, Chvymn99 and 6 others like this.
  13. Eric VW
    Soapstone is incredibly dense. More so than fire brick I should think.
    I wonder how tough it is tho, in terms of abrasion resistance, and being used as a fire box liner. I have zero experience with it.
    Either way, get some fresh and pack ‘em in there scavenger :salute:
  14. Eric VW
    9.5”..... hmmmm..... I don’t see any that long offered by USSC.... I’ll keep looking.
    T.Jeff Veal, Chaz, Chvymn99 and 3 others like this.
  15. scavenger
    scavenger
    Oops. Make that 9...I'm always thinking things are longer than they actually are...
    T.Jeff Veal, MikeInMa, Chaz and 4 others like this.
  16. jo191145
    I need to revise my memory. Measured one in my fireplace. 8 5/8” heavy.
    Soapstone could be cut into one piece slabs. Maybe two on the bottom for easy removal.
    Never saw a soapstone stove that did t have soapstone inside. It works just fine and holds its heat for longer durations of,,,,,,whatever your durating. ;) :)
  17. Eric VW
    Cool. Like said- no experience with it.
    Definitely aware of its heat holding and dissipating characteristics. :yes:
    T.Jeff Veal, Chaz, Chvymn99 and 2 others like this.
  18. Canadian border VT
    I have the soapstone lined fire box in my IS.. IME it is much more durable then fire brick and I haven't broken it yet. Neither have any of my house has many visitors some of whom were not known to be gentle:yes:
  19. Backwoods Savage
    Just ask anyone who owns a soapstone stove. Yes, the stone can crack but it is rare. When used for fire-brick, I doubt there would be much chance of cracking as they are against something solid. Still, there is nothing wrong with using standard firebrick.
  20. Backwoods Savage
    How often? Only when needed and that is not very often.
    T.Jeff Veal, Chaz, Chvymn99 and 4 others like this.
