Tale of two sides.
Discussion in 'The Wood Pile' started by GrJfer, Aug 3, 2019.
  1. GrJfer
    GrJfer
    The Woods of Arkansas
    I sell a little over a cord of wood each fall to help off set saw fuel and maintenance costs. Here is 4 face cords/ric of wood stacked within a couple of weeks of each other. One side gets direct morning sun and the other is partially shaded through the afternoon.
    JDU, Woodsnwoods, jrider and 26 others like this.
  2. buZZsaw BRAD
    looks like nice stuff and ready to burn. Id buy that in a heartbeat!
  3. Backwoods Savage
    So, they are a different color which really does not tell anything. Wondering what your point is?
  4. GrJfer
    GrJfer
    Without a moisture meter check, that is true. I was just pointing out the weathering of the full sun side versus the non full sun side.
  5. Backwoods Savage
    Funny but I've had sides like that even when both are in the sun or both with no sun. Perhaps rain makes a bigger difference than we think sometimes?
  6. Reloader
    Reloader
    NW Oregon
    Interesting.
    The Alder here goes through quite a bit of color changing during the seasoning process. I haven’t paid any attention if the sun or shade makes a difference. We sure get more sunlight on the wood pile after they logged the property behind us.
    Just took a quick look and the stuff on top has bleached out more than the wood in the shady part of the pile. [​IMG][​IMG]
  7. Loon
    Loon
    North of the border
    Went out and checked the top of the pile today Gr and found this. :coldone:
    Around 6 weeks.
  8. JoeinO
    JoeinO
    NEO
    Interesting indeed! One of many reasons I became a FH is getting ripped off buying so called seasoned firewood. Like GrJfer and not owning a moister meter
    I have made this observation. I store wood in a few different places and it is obvious which wood dries faster. Wood up by the patio gets a little more sun but is blocked by part of the house from getting prevailing winds and as much rain. Stack down below the house gets less sun but more wind and rain, it seasons much faster. What has become a simple truth for me is they call it seasoned wood for a reason. I hope some others can chime in. Sorry for being so wordy.
    Just love this topic
  9. jrider
    jrider
    I think the more gray side shows a lot. The sun turns the wood gray and the more sun, the more drying going on. I have found even a few hours per day less sun makes a huge difference throughout a period of even just 6 months. Many of you in here have seen my “piles” and I can tell you orientation even makes a difference. I have found that running my windrows north-south dries better than running them east-west.
  10. Firewood Bandit
    Firewood Bandit
    The unsplit pieces are not firewood. It doesn't start to truly season till it's split.
    Also when using a moisture meter it must be taken internally on a fresh split not on the end.
  11. Loon
    Loon
    North of the border
    Its still out by the splitter and will split and meter it in a bit Bandit.:salute: :cheers:
  12. buZZsaw BRAD
    curious to see the readings on the pictured logs once split
  13. buZZsaw BRAD
    Unfortunately all my stacks are in shaded areas. One stack of red oak gets some sun. The sun and wind do make a world of difference in drying wood. I have a stack/mound at an area im currently cutting and am amazed how well its dries in the full sun. IMG_0556.JPG
    The logs are maybe two years old uncut.
  14. billb3
    Wood will season in the round and it will also season in log form.
    I've actually done both.
    It's a slower process, but it is a process nonetheless.
  15. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have some 30 inch rounds of hard maple the sun has baked for a few weeks. Dry as dry can be!!!! Guessing you can make syrup out of the middle they are so wet! Nice stacks you have.
  16. Loon
    Loon
    North of the border
    Ended up getting the fan and tent set up and did some splitting today and got a whack done.:yes:
    Here's that sun burnt block.
    :coldone:
  17. buZZsaw BRAD
    good looking work Loon ! What species is the sun burnt block?
  18. Loon
    Loon
    North of the border
    Thanks buzz and it was an easy splitting elm with some maple and ash in todays pile.:coldone:
  19. JoeinO
    JoeinO
    NEO
    Good stuff and thanks folks. Now recently hauling out probably 3 cords I had rows stacked tight together it has been there uncovered for at least 2 years.
    The row in front Which had more exposure and stuff on top is totally gray. The swamp white oak which has been there at least 3 years but buried in the back
    I'm guessing from the weight look and the sound of knocking together will need to dry more. Yikes, so species seems to matter a lot. Now bark side up verses
    bark side down? I have read bark side down is better which makes sense I guess. How can Elm stand there unsplit and if you wait for the bark to fall off it
    can be dry as a bone? Hmmm
    Chazsbetterhalf and Chvymn99 like this.
