  1. Need Heat from wood
    Need Heat from wood
    Will a pellet stove (4 inch flue) work efficiently if connected to an 8 inch flue, or will I need to run the 4 inch flue pipe up the 8 inch flue?
  2. Chaz
    Chaz
    Southwestern NY
    It's my (albeit limited) learning from this site that it is acceptable to go from a smaller flue pipe to a larger size pipe, but not to go smaller.
    However, going from 4" to 8" may cause draft issues.
    If you can run the 4" up the 8" stack, it may be the safest option.
    $.02
  3. brenndatomu
    Since an 8" pipe is 4 times the area that a 4" has (12.5 vs 50) I'm saying it won't draft well without going to the top with the 4"
  4. Eric VW
  5. imacman
    imacman
    Denver, NC
    I ran a 4" pipe into an existing 10" wood stove pipe (see pic). No problems at all.
  6. Need Heat from wood
    Need Heat from wood
    Thanks for the input, this is what I was thinking would be the case.
  7. Eric VW
    Welcome to FHC Need Heat from wood :salute:
    Where do you live in VA, roughly...?
  8. Eric VW
    Seems it’s a pellet stove, WW....:salute:
  9. wildwest
    :rofl: :lol: you caught it before I deleted it!!
    Nice to meet you Need Heat from wood , ETA, take note of Imacmans post, he knows his stuff :)
  10. Eric VW
    :picard:
    :BrianK: .....minus the beard and cane....:wacky:
    :D
    :D
  11. wildwest
    and again :picard:
  12. Eric VW
    S’all good, sista!:yes:
  13. Well Seasoned
    It should vent ok. We add top vent options all the time to the Harman's and vent them into pre existing chimneys so long as the chimney lining is in good shape. If there is drafting issues and the stoves draft can be adjusted, that is something that can be done.
  14. brenndatomu
    I guess I should have asked if it was natural draft, or has a blower...I'm sure that makes a difference too...(maybe all pellet stoves have a draft blower?)
  15. Lousyweather
    Lousyweather
    that being said, a central chimney (no sides exposed to the elements) will draft better than a chimney with 3 sides exposed to the elements, the idea being the exhaust gasses cool more before reaching the top of the chimney and slow down. So, a 4" exhaust adapted to a larger, intact flue will work better in a central chimney. Also do not forget that virtually all (with the exception of the Wiseway) modern pellet stoves use a fan to expel exhaust (combustion fan), so this system actually doesn't rely solely on natural draft to expel exhaust. Of course, the chimney should be checked for structural integrity first. If thats questionable, use a liner. If its an old brick or stone chimney without a good clay liner, use a liner anyways. And of course you all know not to use a liner smaller than the stove outlet.
    badbob, Eric VW, Chaz and 5 others like this.
  16. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The pellet stove being a FORCED draft the 4 to 8 connection is going to work just fine.
    The only caveat will be the possible build up up ashes in the lower "ledge" where the transition occurs.
    Depending on the chimney height this could be a paint to clean out.
  17. Pete Zahria
    Pete Zahria
    New Hampster
    I have absolutely no problems with that.
    Using the same ~40 year old chimney that I have used with
    Wood stove
    Coal stove
    Now pellet stove...
    Dan
  18. imacman
    imacman
    Denver, NC
    Never seemed to be an issue with mine. That said, I still ran the Lint Eater brush high enough so I knew it was at the "ledge" level, let it flop around for 5-10 seconds there, and that was it. Even if some ash built up on that ledge, it would form a small triangular shape, and not affect air flow at all.
    Eric VW, Chaz, Well Seasoned and 3 others like this.
  19. brenndatomu
    Seems like y'all have things under control over here in pellet land...I'll just crawl back in my log now...:whistle: ;)
    :tip:
    Eric VW, Chaz, Well Seasoned and 4 others like this.
  20. imacman
    imacman
    Denver, NC
    :handshake:
    Eric VW, Chaz, Well Seasoned and 2 others like this.
