How much longer for you?
Discussion in 'The Wood Pile' started by Backwoods Savage, Jul 28, 2019.
  1. Backwoods Savage
    I figure we're from 6-8 weeks away from the start of wood burning. Can hardly wait! I've had enough of summer weather. However, if it would stay in the 70's I would not mind that at all. Then cool off in September and even more in Octember.
  2. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Hopefully no more than 3 months here. Can’t wait to see the snow blowing sideways. The heat has been oppressive.
  3. Midwinter
    I'm in S NH, typically don't burn until late October, early November. But we have natural gas/forced hot water heat as well.
    Some years we get a cool-down in late August, and we always close the pool by mid September because the water is too cold. I'm looking forward to crisp fall air for sure!
  4. thewoodlands
    thewoodlands
    We usually start burning on September 15 unless it's warm out, we started burning on that date once we had shoulder season wood up. Each year we have 12 face cord up (two years worth), we burn four in the fall and the other two once spring hits.
  5. papadave
    7 weeks maybe?
    I'd like to get more wood in the shed first......mostly SS stuff, although there's enough in there for this winter.
  6. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Hopefully not for s long time. I like burning wood an all, but I hate winter!!!:mad:
    Usually start night burns in October then 24-7 after Halloween
  7. Backwoods Savage
    I'm beginning to think about bringing some wood to the barn. I usually do that in October but seems every year it cuts into some hunting time. Also I would like to cut some wood in October this year if possible.
  8. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I usually start end of October, but we installed a pellet stove in basement last year, which produces more heat than anticipated. So I’ll probably start up the wood insert in mid to late November . The “start” of winter in southern New England varies drastically in what the temps could be. Pellet stove may have solved shoulder season burning.
  9. Chvymn99
    Usually right around Halloween time frame... but last year it was a few weeks earlier... will see. This years heat hasn’t really been that bad all in all... we’ve had a few days of heat and high humidity, but not like years past. Will have a few more hot days before September, but hopefully will have a nice fall.
  10. Eric VW
    Last year or the year before we had to have a small fire to knock the chill off in mid September, but not until mid October after that... usually mid to late October here. We shall see.
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    first frost will be 2nd or 3rd week of sept....usually. pellet stove upstairs so wont light the beast unless its cold and rainy in sept.
  12. fox9988
    fox9988
    NW Arkansas 72717
    I'm probably 3 months out.
  13. Canadian border VT
    You Southerners :picard:.. I generally start burning October first to 15th by we have snow on Halloween.. for those of you with kids, here you always have to buy Halloween costumes three sizes too big so the snow suit can fit underneath it:rofl: :lol:
  14. In the Pines
    In the Pines
    It will be around thanksgiving at the earliest most likely usually not until December though.
    I just need it to quit raining so I can get the truck into the backyard and bring wood in.
    We keep getting these downpours of close to an inch. Just saturates the ground. Already rutted the middle of the yard this summer, thinking it was solid enough.
  15. Aje1967
    Aje1967
    Kenosha, Wisconsin
    It is 90F here now so not thinking too much about the fireplace. Have not even been checking in here too often :(. I know winter is coming. Probably start sometime in mid October.
  16. jrider
    jrider
    I fire up the OWB in mid October just to keep the chill out of the house. It’s our only source of heat since I refuse to buy oil.
  17. billb3
    Usually not until after Halloween here.
    I can wait. Don't mind the heat.
  18. brenndatomu
    Usually late October, but was mid October last year...so 10-12 weeks?
  19. In the Pines
    In the Pines
    I just took the mower out to the back 40 and almost got myself stuck. I'm in no hurry for winter, although I like the cold.
    It just means wet season to me right now.
  20. Well Seasoned
    Snows flying 2nd or 3rd week in October, so hopefully another 8+ weeks. Can't wait for leaf peeping to begin!
