Stihl bars worth it
Discussion in 'Chainsaws and Power Equipment' started by Yawner, Jul 13, 2019.
  1. Yawner
    Yawner
    Louisiana
    Stihl is a great brand and they certainly charge for it! As for Stihl bars, do you use them, do you think they are worth it?
    I need a bar/chain for a Stihl 026 in great condition with .325-07 sprocket. Bought it used and had no bar. Would be for limbing, bucking and general use except not big stuff, got a 362 for that. Dealer wants $43 plus tax for a 16" bar and $23 for chain. (Stihl says 026 can run 16, 18 and 20 inch bars but hmmm, not sure about 18 or 20.) A bazillion people use Oregon or other brands, just wondering what to buy. Every ounce counts and I don't mind spending when it matters. At my age, thinking of looking into getting a lightweight bar. Also not sure how much a bar/chain would cost from Oregon or other. What's your take on bar/chains?
  2. NBourque
    NBourque
    I like the stihl bars only cuz they match my stihl saws but I don’t think you can go wrong with Oregon bar n chains. Prob be cheaper too.
    Hammy, amateur cutter, Chaz and 3 others like this.
  3. T.Jeff Veal
    I like the Stihl bars, I posted a thread asking about the lite weight bars, every response was go with Stihl. I'm getting a Tsumara 28" bar and 3 Stihl chains, just case I got a good deal on it. Oregon makes good stuff, chain seems to stretch a bit more, Stihl is just better, will last a long time...
    Hammy, amateur cutter, Chaz and 2 others like this.
  4. buZZsaw BRAD
    I have Stihl 16 & 20" bars for my 290, and a 28" for my 460.
    The 460 was bought without a bar, but two chains for a 20" bar. I bought a 20" Oregon bar and its fine. Id prefer Stihl, but am CHEEEEP! Also bought a Laser 36" bar for the 460 to fell a large white oak last Fall. Ive used it a couple times to buck large wood.
    IMO Oregon will work fine. Ive used their chain for years without issue. If you are using the saw for many hours every day, then id go lightweight or if you do a lot of limbing, cutting of skinnies etc where the saw is being moved and lifted a lot.
    The 260 is a lighter weight saw if memory serves me correct. Just got a 261 myself for the light weight.
    Im "brand loyal" and it bugs me to have different brand bars on them them, but oh well, still cuts thru the logs! IMG_0495.JPG
    460 with Oregon bar from same cutting.
    MFMc., Hammy, Boogeyman and 5 others like this.
  5. Backwoods Savage
    I used to use Oregon all the time but since I bought a Stihl saw I've run nothing but Stihl and I like them. I think they may wear a lot better than the Oregon. The price you were quoted seems a bit high but I have not bought for a while now so not up to date on prices.
  6. amateur cutter
    I too like the Stihl bars. They wear well & long & the lightweight bars are very durable. If you do a lot of limbing with the 026 I might suggest a 20" bar with .325 chain. The saw will pull it decently & you do much less bending over. Don't expect to bury the bar in 20" Oak & cut real fast though.
    MFMc., Chaz, Hammy and 3 others like this.
  7. Fifelaker
    Fifelaker
    Fife Lake Mi.
    The last Oregon bar I bought was made out of some kind of cheese (thank you DSS for that analogy). I think I got maybe 15 cord on it when it was trash, I have several Stihl bars that have hundreds of cords on them and they are still in decent shape. I bought a Forester green bar for my 026 that has at least a hundred cord on it and I just dressed the rails the first time the other day.
    Chaz, Stlshrk, Hammy and 3 others like this.
  8. farmer steve
    farmer steve
    top of the hill york co. PA.
    I run only Stihl bars and chains cause I'm cheap and want something that lasts. The 026 will run an 18"/.325 no problem. I think 20" is pushing it for that saw. Talk to you dealer and ask what deal he will give you on a bar and multiple chains. My dealer does buy 2 get 3rd free year round. My 18" chains are $24.49 so I get 3 chains for around $50.
  9. jo191145
    In my not so learned opinion. In the realm of.325 chains I go with Stihl over husky/Oregon. I’ve just noticed a huge difference in quality and performance. Once you get to 3/8”s the gap narrows a bit more.
    Carlton makes a good chain too and relatively cheap.
    Can’t say I’ve worn out enough bars to give an opinion on them.
  10. Backwoods Savage
    I'd like some others to chime in on this too. Maybe huskihl and Armbru84
    Chaz, Hammy, jo191145 and 1 other person like this.
  11. Backwoods Savage
    Geeze Bud, did you buy that bar in Wisconsin?
    Chaz, Fifelaker, Hammy and 3 others like this.
  12. mirnldi
    mirnldi
    I had good luck too with Carlton. But nothing stays sharper longer than a stihl chain
  13. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I'm not sure where the Limburger came from but it sure did stink.
  14. Armbru84
    Armbru84
    Sparta, Michigan
    Stihl makes good bars but the newer Oregon Versacut are good bars. I run a lot of Tsumura bars as well.
    Unless your doing a boatload or cutting they will all stand up. Oregon, Stihl, Cannon, Tsumura, laser, etc. keep a good sharp chain on it and make sure the saw is piling good and you should be set.
  15. Jon_E
    Jon_E
    Southwestern Vermont
    Lots of choices. I liked Stihl bars when I ran Stihl saws, but my Dolmars have Oregon bars on them. Not a pro, so unlikely to put something like a Cannon or a Sugihara bar on my saws. They are expensive. Used to really like the orange GB Titanium bars from Australia but it has been very hard to find them, not sure they are importing them to the US anymore.
    Chaz, farmer steve and T.Jeff Veal like this.
  16. Oldman47
    Oldman47
    Illinois
    My 026 has a OEM 20 inch bar and works just fine with that .325 chain that came with it.
    Chaz and farmer steve like this.
