Its in good shape for a 20 year old truck in PA. He told me the trans gets hot so had it checked and the cooler bypass is open. Gona fix that saterday and install a 6.0 trans cooler while I'm working on it.
Had to take care of something befor realy loading it down. 7.3 trans cooler in front mine was blocked up and the fluid was going through the bypass. Replaced with an 04-05 6.0 cooler over double the size and direct bolt in so why not upgrade while you replace.
