Outside spigot plumbing question
Discussion in 'The DIY Room' started by Midwinter, May 22, 2019.
  1. Midwinter
    We had a plumber here, and he wanted to start cutting holes in the basement ceiling. He left without doing anything.
    Couldn't we just replace the faucet? Thanks for any info.
  2. Chaz
    Chaz
    Southwestern NY
    I've never seen a spigot like that
    :confused:
    I wonder why there is a hole in the one shaft
    :sherlock:
    Does the top knob turn the water on/off?
    If so, then I'm lost on the purpose of the second knob and the hole
    :wacky:
  3. Midwinter
    The green knob turns the water on and off. When the hose isn't attached, no water comes out of the little hole in the stem.
  4. In the Pines
    In the Pines
    I wonder if that is some kind of frost spigot, never seen one like it.
    But if it froze, water would go that way instead of bursting a pipe in the house.
    You could probably replace the handle stem, definitely the spigot. Shouldn't be a big job.
  5. Chaz
    Chaz
    Southwestern NY
    Maybe that hole is for freeze protection, I dunno.
    It looks like that valve could be removed and replaced, but you'd have to shut water off to that spigot first.
    Hope someone has some good advice for ya.
  6. Midwinter
    That's kind of what I thought. It's not very old. I'll try and go back through receipts to figure out which local plumber installed it in the first place. Presumably, they would know how it fix it.
  7. TurboDiesel
    I put one in like that recently [not a frost free] and it did the same thing last week. not sure why...
    it was inside and never froze.
    I turned it off and back on and it was fine then...
  8. Chaz
    Chaz
    Southwestern NY
    From some googling, it looks like a "frost free, anti-siphoning" faucet.
    Seems like yours is a common problem.
    :doh:
    I also read that most "code" mandates them now.
    :picard:
    Just seems like one more expensive "gadget" that homeowners are being forced to purchase, whether they work properly or not.
    :mad::mad:
    I cannot think of many instances in which my garden hose is gonna suck water back into my domestic supply and contaminate it.
    :loco: :crazy:
  9. Midwinter
    Thanks for looking into it, Chaz.
  10. stuckinthemuck
    stuckinthemuck
    Is there a brand and model number on there? Might be able to dig up a parts diagram. I replaced one of those 2 years ago. Had to solder it inside the house. The whole thing was about a foot long.
  11. stuckinthemuck
    stuckinthemuck
  12. Chaz
    Chaz
    Southwestern NY
  13. In the Pines
    In the Pines
    I always thought stems were solid. I'm curious in what you find out.
    it would cost more to drill out the stem. Can't see that being a cost saving feature.
  14. Midwinter
    Thanks for finding that! It doesn't look too bad, at least we can open it up and see what we are dealing with.
  15. brenndatomu
    Exactly.
    You'd be surprised...
    You should be able to repair it without taking anything apart inside...might just need a little canoodling, no parts...but if it does need parts I would expect to be able to buy a rebuild/repair kit for ~$10 or so...
  16. brenndatomu
    Try putting a squirter nozzle on the hose, turn the hose bib on the whole way, open the hose nozzle the whole way and then let it slam closed...do this a few times...might be able to make the check valve or whatever is stuck reseat itself...
  17. Midwinter
    Great, that's what I want to hear. My husband is the mechanically inclined one, so that's his weekend project now. He's the one who uses it anyway, to spray the pollen off his car.
  18. brenndatomu
    There should be at least a brand listed on it somewhere...maybe a model too...should be easy to find parts diagram then. Can probably order a repair kit from many different sources then too...
  19. Midwinter
    I'll take a look tomorrow.
  20. stuckinthemuck
    stuckinthemuck
    Great. Now we are all going to be up all night with anticipation. Just like they used to say, “next week on (insert your sitcom here)” back in the 80’s.
